coq-club - Re: [Coq-Club] overloading natural number notations for user types
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] overloading natural number notations for user types
  • Date: Fri, 19 Feb 2016 19:00:51 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f49.google.com
  • Ironport-phdr: 9a23:zadaBhFVqgTo0RC34Dhkh51GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27WQ7vmrAzZIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbvotaJOU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+VWMfjhpBBUDh4RDkU5Ht+n/4sex82ySeMMDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
Thanks, Robbert. Unfortunately, I guess this means "not without a plugin". Instead, I'll just define hopefully enough numbers via Notations...
-- Jonathan
On 02/19/2016 04:59 PM, Robbert Krebbers wrote:
Hi Jonathan,
The parsers for numerals are implemented in OCaml. See for example plugins/syntax/nat_syntax.ml in the Coq source tree.
Best,
Robbert
On 02/19/2016 10:52 PM, Jonathan Leivent wrote:
Is there a way in Coq to overload the natural number notations? There
seems to be, because 42 in Z_scope is a Z, and 42 in bigZ_scope is a
BigZ.t_. However, in neither case is the Notation "42" itself defined.
At least in the case of bigZ_scope, the only notations defined are "0",
"1" and "2" (in Numbers/Integer/BigZ/BigZ.v) - and those are Local. So,
what magic makes it work for all other natural number notations as
well? And can it be used for user-defined types?
-- Jonathan
