- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq-related jobs at Princeton, Penn, Yale
- Date: Tue, 23 Feb 2016 13:37:37 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=1337777.net AT gmail.com; spf=Pass smtp.mailfrom=1337777.net AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f193.google.com
- Ironport-phdr: 9a23:LApmnBF/x41UTKAXknVk+J1GYnF86YWxBRYc798ds5kLTJ75pM+wAkXT6L1XgUPTWs2DsrQf27WQ7v2rCTZIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbvptaDOU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y5FCT5J2kUXXECRtUqhAciu7W38u/ZV1yyTPMmwRrcxD2fxp5x3QQPl3X9UfwUy93va35R9
Proph,
Short : now [1] is successor from the earlier [2], and presents some
Coq program of the congruent resolution technique (« particular cut
elimination ») of the oriented equations of adjunction as presented by
Dosen [3]. Here some alternative (equivalent) terminology
(formulation) is given such that each primitive rewrite equation is
saturated (augmented) congruently such to command (« operate ») deep
at any node (subterm), and this terminology contains some memory which
memorize the links (« effects ») on the composition nodes. For example
[6] the command F (G f2 o G f1) ~> F (G (f2 o f1)) , is some
congruent (bellow F) rewriting of the functoriality of G, and
memorizes that the outer composition is linked to the inner
composition. In some sense, doing categorial programming may be
comparable to doing the common « small-step operational semantics,
Hoare memory logic » of C !?1
Congruence is indeed the critical angle of view of the common «
small-step semantics » [4]. Also are there correlations between this
categorial « congruent resolution » technique and the common « deep
inference » technique ? And earlier in [2] , which proved «
total/global cut elimination », although some non-saturated congruent
« small-step semantics » was held, it is possible to formulate some «
big-step semantics » inductive definition which mimicks/simulates the
recursion contained the cut-elimination theorem : therefore small-step
<-> particular and big-step <-> total/global. Also earlier in the
semiassociativity completeness and confluence lemmas, the linking
technique is easier to describe because the commands (for example, the
associativity bracketing command) are in fact terms (arrow terms) of
some easy inductive dependent type.
Also may some shallow embedding onto some logic as « dedukti
modulo » [5] be some more sensible compu-logical context than the
present deep embedding in Coq ?
[1] 1337777.net, «
https://github.com/1337777/dosen/blob/master/dosenSolution1.v »
[2] 1337777.net, «
https://github.com/1337777/dosen/blob/master/dosenSolution.v »
[3] Dosen, «Cut Elimination in Categories» In:
https://books.google.com/books?isbn=9401712077
[4] https://www.cis.upenn.edu/~bcpierce/sf/current/Smallstep.html
[5] Saillard, http://www.cri.ensmp.fr/people/saillard/Files/thesis.pdf
[6] ADDENDUM. Some lemma :
« Lemma lem : forall A, exists f', exists Δ, Δ ⊧ f' *↜a F| (γ| (G|
(@ModIden A) <b G| 1) <b G| 1). »
is solved using this sequence of categorial commands and Coq automation :
« refine (fun2' at ( (bottomF (leftComCoMod (bottomγ (selfCoMod)))))
;; fun1' at ( (bottomF_Refl (rightComCoMod_Refl selfCoMod_Refl))) ;;
NOOP);
repeat (intuition eauto; econstructor). »
___SOLUTION PROGRAMME MEMO___
Short : some Coq program of the termination technique of the oriented
equations of adjunction as presented by Dosen [1]. For example,
(counit f <o reflection (unit g)) ~> (f <o reflection g), which is the
polymorphic (Yoneda) terminology of the common equations. And the
confluence technique and links-model resolution technique for
semiassociativity and associativity was already programmed and
simultaneously-edited and timed-tutored in [2] and [3]. These Coq
programs use dependent types to encode source-target functions and use
inductives to encode grammatical (free) generations of adjunctions.
The Solution Programme lacks to extend and mix these automation
programming techniques into the enriched-lax monoidal topology
(Tholen's TV) or the n-fold-lax categorial homotopy (Riehl's
Kan-obsession) or the dissociativity technique (Dosen's boolean
categories and linear logic) or the compositional automation technique
(Chlipala's ?functorial? MirrorShard)... ultimately this may converge
to the descent technique of Galois. The Solution Programme initiated
by Gentzen lacks to comprehend things in different « terminologies »
or « formulations » or « coordinates ». This angle of view was
continued by Lambek into categories, then by Kelly, then by
Dosen-Petric. Einstein's single deepest angle of view was about «
coordinates », even before the « spin » or the « entropy » ...
[1] Dosen, «Cut Elimination in Categories» In:
[2] 1337777.net, «MACLANE PENTAGON COHERENCE IS SOME RECURSIVE
COMONADIC DESCENT» In: Studies in Logic, SYSU
[3] 1337777.net, «1337777.info»
___
- [Coq-Club] Coq-related jobs at Princeton, Penn, Yale, Andrew Appel, 02/05/2016
- Re: [Coq-Club] Coq-related jobs at Princeton, Penn, Yale, 1337 777, 02/23/2016
