coq-club - Re: [Coq-Club] [ANNOUNCE] jsCoq preview release
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [ANNOUNCE] jsCoq preview release
  • Date: Wed, 2 Mar 2016 21:05:55 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:4xoh5xAHY5Ex3NYrh900UyQJP3N1i/DPJgcQr6AfoPdwSP7/osbcNUDSrc9gkEXOFd2CrakU1KyJ6Ou+CCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb/psMOCKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1AY02AblAZ/OwnZqVTRWp7svib+/r523CSfMMvqC6g1RRyt6q5qTFnjjyJRZG1xy33elsEl1PETmxmmvREqm4M=
Indeed, it's brilliant work; congratulations!
On 03/02/2016 07:43 PM, Arthur Azevedo de Amorim wrote:
> This is amazing news; thanks for this incredible tool, Emilio!
> Em qua, 2 de mar de 2016 às 19:39, Emilio Jesús Gallego Arias
> <e+coq-club AT x80.org
> <mailto:e%2Bcoq-club AT x80.org>>
> escreveu:
> Dear Coq Club,
> we are happy to announce the first experimental release of jsCoq, a
> port of Coq to HTML5/Javascript ES2015.
> jsCoq needs a *pretty recent* browser, either Chrome (>= 48.0) or
> Firefox (>= 45.0). The online demo is at:
> https://x80.org/rhino-coq/
> The project aims to ease the development of interactive Coq documents
> and teaching material, improve the accessibility of the platform, and
> explore new user interaction possibilities.
> This is the first public release; it provides a mostly functional
> basic Coq environment. While basically untested, we feel that the tool
> has reached a point where it could be useful to others.
> Some code is hacky and needs to be reworked, there are known pitfalls,
> expect bugs and problems. More info below.
> Best regards,
> Emilio
> Try & Download:
> jsCoq is free software, source and build instructions are available
> from:
> https://github.com/ejgallego/jscoq/
> Building is a bit involved, there are pre-built versions at:
> https://github.com/ejgallego/jscoq-builds/
> Enabling jsCoq in an existing webpage roughly amounts to adding:
> <script src="js/jscoq-loader.js" type="text/javascript"></script>
> <script type="text/javascript">
> loadJsCoq('./').then( () => new CoqManager (list_of_ids, [options])
> </script>
> YMMV, we would be very happy to help or hear from your experience!
> Current structure is fairly UI independent, so this could be a good
> base to build a different IDE try ideas out!
> Libraries available:
> jsCoq can build against Coq 8.5 or trunk. Our current build is based
> on 8.5 + several hand-picked fixes, we include the following
> libraries:
> CoLoR, cpdt (free parts), coquelicot, flocq, math-comp, mtac,
> relation-algebra, sf, and TLC.
> Let us know if you would like to add your own library to our builds.
> Colla&Coq
> We provide a pastebin-like service at:
> https://x80.org/collacoq/
> it allows to paste and share runnable Coq snippets, it's status is
> extremely experimental, so expect you pastes to be gone.
> Custom build for HoTT:
> We provide an experimental custom build for HoTT:
> - using the HoTT library:
> https://x80.org/rhino-hott/
> A very experimental optimized build for the math-comp library is also
> available (contact me in private).
> Coqdoc to jsCoq:
> Experimental support for generating jsCoq webpages from a coqdoc
> document is available; see the README for more details.
> Users:
> jsCoq was used at the "Advanced Coq Winter School 2016":
> https://team.inria.fr/marelle/en/advanced-coq-winter-school-2016/
> Examples:
> The main page includes a proof of the infinitude of primes by
> G. Gonthier. We provide some more examples as a showcase of the tool:
> + dft.v: https://x80.org/rhino-coq/examples/dft.html
> A small development of the theory of the Fourier Transform following
> Julius Orion Smith III's "The Mathematics of the Discrete Fourier
> Transform"
> + Mtac: The Mtac tutorial by Beta Zilliani:
> https://x80.org/rhino-coq/examples/mtac_tutorial.html
> + Stlc: The "Simply Typed Lambda Calculus" chapter from Software
> Foundations by Benjamin Pierce et al:
> https://x80.org/rhino-coq/examples/Stlc.html
> + StackMachine: The First chapter of the book "Certified Programming
> with Dependent Types" by Adam Chlipala:
> https://x80.org/rhino-coq/examples/Cpdt.StackMachine.html
> Acknowledgments:
> jsCoq development has been funded by the ANR/FEEVER project.
> jsCoq has been written by Emilio Jesús Gallego Arias and Benoît Pin,
> with special thanks to:
> Yves Bertot
> Maximé Dènés
> Hugo Heuzard
> Pierre Jouvelot
> Pierre-Marie Pédrot
> Gabriel Scherer
> Arnaud Spiwack
> Enrico Tassi
> Jérome Vouillon
> Future plans/TODO:
> A better panel layout is coming soon. It will allow different
> placement, resizing. Goal history and diffs should also happen soon,
> as well as a much improved search/logging support.
> There are potentially many useful things to improve, here's a small
> brainstorming:
> + Improve .vo load time: This requires non-trivial, but we could make
> .vo loading an order of magnitude faster.
> + Better CSS/HTML styles: we are lacking in web design manpower so the
> current style could be easily improved.
> + Web editor (CodeMirror) support for Coq still needs a lot of work.
> + Better UI: Current UI is a prototype and may not be flexible enough.
> Better proof display, user queries, an improved search command,
> better display of math would be great.
> + More of Coq's API and data structures could be exported to JS (via
> json_ppx_deriving).
> + Extraction to JavaScript.
> + Better support for html slides/deck.js.
> + Running jsCoq in a separate browser thread (worker).
> + Static vs dynamic linking of .cma plugins is to be considered.
> + Makefile of addons/package format need work.
> + Fixing vm_compute could be done using emscripten.
Attachment: signature.asc
Description: OpenPGP digital signature
