- From: Peter LeFanu Lumsdaine <p.l.lumsdaine AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Composability of coercions, when working with setoids/categories
- Date: Sun, 6 Mar 2016 19:14:42 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=p.l.lumsdaine AT gmail.com; spf=Pass smtp.mailfrom=p.l.lumsdaine AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f45.google.com
- Ironport-phdr: 9a23:MbIQeBMnZC5S2/pJI5Ul6mtUPXoX/o7sNwtQ0KIMzox0KPn6rarrMEGX3/hxlliBBdydsKIbzbWH+Pm4CSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb/jsMSLM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4kX3kbiFJsDibM6gyyeor0qSfzt+xwkH2Ce8mwSa0xQjir7qFmYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
Here’s an issue which I’ve run into in several different developments recently, when working with either setoids or categories, and maps/functors between them considered as a setoid/category themselves. I’m hoping that others may have come across similar issues before, and found better workarounds than I have so far.
The short version is that I have two coercions, which *look* like they’re of the form [ c1 : A >-> B ], [ c2 : B >-> C ], so I expect to be able to use a term of type A as a term of type C. However, the domain of the second coercion is actually not B itself but B', where B reduces to B'; and so the coercions do not quite compose.
The following MWE is closely based on a true story; names have not been changed, but in the original, all these record types of course have further fields:
---8<---
Record setoid := { setoid_base :> Type }.
Record setoidmap_internal (X Y : setoid)
:= { setoidmap_function :> X -> Y }.
(* Setoid maps themselves form a setoid: *)
Definition setoidmap (X Y : setoid) : setoid
:= Build_setoid (setoidmap_internal X Y).
(* Only [setoidmap] is used from here on, for a long time;
[setoidmap_internal] never appears explicitly,
and we have the illusion of a coercion [setoidmap >-> Funclass]: *)
Definition test1 (X Y : setoid) (f : setoidmap X Y) (x : X) : Y
:= f x.
Record monoid := { monoid_carrier :> setoid }.
Record monoidmap (X Y : monoid)
:= { monoidmap_function :> setoidmap X Y }.
(* We also appear to have a coercion [ monoidmap >-> setoidmap ].*)
(* However, we don’t get a composite coercion [ monoidmap >-> Funclass ]: *)
Definition test2 (X Y : monoid) (f : monoidmap X Y) (x : X) : Y.
Proof.
try exact (f x). (* fails! *)
exact ((f : setoidmap X Y) x). (* succeeds *)
Defined.
---8<----
The problem (if I’m understanding it right) is that the first coercion really goes [ setoidmap_internal >-> Funclass ], whereas the second really goes [ monoidmap >-> setoid_base ], and so they are not composable. The illusion of composability comes from the reduction [ setoid_base (setoidmap X Y) ~~> setoidmap_internal X Y ], and is reinforced by the fact that [ setoid_base ] is itself a coercion.
The two main solutions I have found are changing the type of [ monoidmap_function ] to [ setoidmap_internal X Y ] in the definition of [ monoidmap ], or else explicitly giving the “midpoint” of the coercion composition at the point of use, as in the successful proof of [ test2 ] in the MWE. However, both of these break the nice abstraction/illusion provided by the coercion [ setoid_base : setoid >-> Sortclass ], which otherwise allows us to never mention [ setoidmap_internal ] explicitly.
Does anyone have a way of setting the definitions up that allows this abstraction/illusion to be preserved?
Best,
–Peter.
- [Coq-Club] Composability of coercions, when working with setoids/categories, Peter LeFanu Lumsdaine, 03/06/2016
