- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction over two non-mutual inductive terms
- Date: Tue, 8 Mar 2016 16:14:12 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:nmur1RHOU1TzzmJ5PdJZfJ1GYnF86YWxBRYc798ds5kLTJ75pMuwAkXT6L1XgUPTWs2DsrQf27WQ4/yrADZfqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0q8GYOl8XzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB34dlQZUSwPC6grmV531v2OureZ23y+BIcTeVqEuHzmu8vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Per,
"i" is just a nat, so the well-founded relation would simply be the less-than operator. But even so, I'm not certain how this would help. My eval function is defined as follows (for brevity I'm omitting some rules):
Variable type : context.
Inductive Result : Type :=
| Value : t -> Result
| Error : Result
| Overflow : Result.
Fixpoint eval (i : nat) (tm : t) {struct i} : Result :=
match i with
| 0 => Overflow
| S i' => match tm with
| (t_Var _) => Error
| (t_Num n) => Value (t_Num n)
| (t_Plus t1 t2) => match eval i' t1, eval i' t2 with
| Value (t_Num n1), Value (t_Num n2) => Value (t_Num (Zplus n1 n2))
| _, _ => Error
end
| (t_Cond b t1 t2) => match eval i' b with
| Value b' => match b' with
| t_Num n => if Z.eq_dec n Z0
then eval i' t1
else eval i' t2
| _ => Error
end
| _ => Error
end
| (t_Lam x t) => if bclosed (t_Lam x t)
then Value (t_Lam x t)
else Error
| (t_App t1 t2) => match eval i' t1, eval i' t2 with
| Value (t_Lam x t1'), Value c2 => eval i' (tsubst_t t2 x t1')
| _, _ => Error
end
| (t_Bind x t1 t2) => match eval i' t1 with
| Value c1 => eval i' (tsubst_t c1 x t2)
| _ => Error
end
| (t_Rec y x t) => eval i' (t_Lam x (tsubst_t (t_Rec y x t) y t))
end
end.
I also have a separate type checking function. The theorem that I am trying to proved is that whenever a term is well-formed (i.e. it type checks, and has no free variables) then eval will not emit an error.
Thanks
Scott
On Tue, Mar 8, 2016 at 3:57 PM, Per Lindgren <Per.Lindgren AT ltu.se> wrote:
Hi
Without knowing details of your problem, it seems similar to a problem we faced. Is it possible to define a “measure" (well founded relation) for i?
Best,
Per
> On 08 Mar 2016, at 21:41, scott constable <sdconsta AT syr.edu> wrote:
> Hi All,
> I have a simple recursive programming language implemented in coq with an evaluate function "eval". Since the language is non-normalizing, eval is recursively defined over a nat counter, "i" (I'm following the strategy given in the ImpCEvalFun chapter of SF). I'm currently trying to prove that whenever a term "tm" in the language is well-formed, no error can occur during a computation. So the theorem is as follows:
> Theorem NoFail : forall i tm, well_formed tm -> eval i tm <> Error.
> It seems that I need to induct over both i and tm, but doing something like
> induction i as [|i'], tm.
> always leads to unprovable subgoals, such as
> IHi' : eval i' (t_Plus t1 t2) <> Error
> eval (S i') (t_Plus t1 t2) <> Error
> when what I really want would be something like
> IH1 : eval i' t1 <> Error
> IH2 : eval i' t2 <> Error
> Any help would be much appreciated.
> Thanks,
> Scott Constable
- [Coq-Club] Induction over two non-mutual inductive terms, scott constable, 03/08/2016
- Re: [Coq-Club] Induction over two non-mutual inductive terms, Per Lindgren, 03/08/2016
- Re: [Coq-Club] Induction over two non-mutual inductive terms, scott constable, 03/08/2016
- Re: [Coq-Club] Induction over two non-mutual inductive terms, roux cody, 03/08/2016
- Re: [Coq-Club] Induction over two non-mutual inductive terms, Guillaume Melquiond, 03/09/2016
- Re: [Coq-Club] Induction over two non-mutual inductive terms, scott constable, 03/24/2016
