coq-club - Re: [Coq-Club] coq_makefile question
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] coq_makefile question
  • Date: Tue, 15 Mar 2016 11:46:55 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.boutillier AT pps.univ-paris-diderot.fr; spf=None smtp.mailfrom=SRS0=BSo3=PL=pps.univ-paris-diderot.fr=pierre.boutillier AT bounce.ens-lyon.org; spf=Pass smtp.helo=postmaster AT sonata.ens-lyon.org
  • Ironport-phdr: 9a23:1SM1fhLN5Gc6y/We99mcpTZWNBhigK39O0sv0rFitYgULPjxwZ3uMQTl6Ol3ixeRBMOAu6IC07Kd7vyocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC34Lvj6vvp9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6353YGSGheuB1VHwnB6BD3RN+lqir3rPBwniOdINH3SbQ1VC6K979wDgLuiTlCLzcj8XqShs18gbhcvFSvvUoskMbvfIiJOa8mLevmdtQASD8ZUw==
The command bin/coq_makefile -impredicative-set > foo should returns the
warning:
>> Please now use \"-arg -impredicative-set\" instead of
>> \"-impredicative-set\" alone to be more uniform.
It does not. This is not my problem anymore :-)
Similarly, bin/coq_makefile -custom foo bar mli should have told you
>> Please now use \"-extra[-phony] result deps command\" instead of \"-custom
>> command deps result\ ».
>> It follows makefile target declaration order and has a clearer semantic.
which would have answer your question.
Cheers,
Pierre B.
> Le 15 mars 2016 à 11:02, Matej Kosik
> <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
> a écrit :
> Hi,
> I am now going over "Make" files which come with coq-contribs.
> Some of them contain "-custom" commands.
> It does not seem to be documented, i.e.
> coq_makefile -h
> does not mention it.
> Is this undocumented (?) on purpose or by mistake?
> Also, I would like to ask how is "-custom" command different from "-extra"
> (other than syntactically)
> M
