coq-club - Re: [Coq-Club] multiple typeclass instance question
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] multiple typeclass instance question
  • Date: Tue, 15 Mar 2016 17:07:27 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f54.google.com
  • Ironport-phdr: 9a23:KXAv2xSTrp0XUqoQniJTQXQN39psv+yvbD5Q0YIujvd0So/mwa64YBWN2/xhgRfzUJnB7Loc0qyN4/CmATRLuMzb+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq82VO10D3WDnKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxzhPBQHZ7Bj8FrP8szX3sPY1jCudO8z1QLQ5VByt6q5qTFnjjyJRZG1xy33elsEl1PETmxmmvREqm4M=
On 03/15/2016 04:25 PM, Matthieu Sozeau wrote:
Indeed, it seems this would require pretyping (refinement from untyped terms
to
typed terms) to be done similarly to what the old refine tactic did (or Idris
does AFAIU). You'd have a tactic pretype that takes a untyped term and
produces
a typed one, with clauses like:
pretype (forall x : T, b) = mkProd x; [pretype T| pretype b]
pretype (fun x : t => b) = mkLam x; [pretype t|pretype b]
pretype (f a) = refine (_ _); [pretype f|pretype a]
pretype ($(tac)$) = tac
pretype (_) = try typeclasses eauto
pretype (match x with brs) = evar(T : Type); subst T; unshelve (evar (t :
?T));
[pretype x| mkCase t; pretype brs]
I think that would not be too hard to implement (the devil's in the details
though).
I'm not so sure it is desirable to have the regular type inference be
implemented like
that, but that would make a fun experiment.
-- Matthieu
I think I get the idea - and it seems very interesting! I didn't know it would even be conceivable to factor typing in Coq out into the untrusted world of tactics without creating havoc.
So, this would address both of Arnaud's points below.
I find it ironic that, just as people are coming up with interesting typed alternatives to Ltac, that perhaps these alternatives would need to rely on Ltac to do typing.
-- Jonathan
On Tue, Mar 15, 2016 at 8:36 PM Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr
<mailto:aspiwack AT lix.polytechnique.fr>>
wrote:
Without understanding what the pretyper does, is the implication of
not
having any backtracking in the pretyper that Coq can't change the
decision about the type of any term once it is typed?
This is correct, but I’d say this should be seen as two things:
1. There is no backtracking in the pretyper, so it doesn’t know how to
produce a second type if a first one has been invalidated
2. Even if there was, if it wasn’t implemented using the abstraction
provided by the tactics a type couldn’t be invalidated due to a
tactic
failing
Does this restriction on backtracking in the pretyper also imply that
experimental typed alternatives to LTac, such as MTac, would all be
incapable of backtracking after a successful solution of a type? If
so,
would the potential solution of the issue for tactic-in-term also
improve the situation for MTac-like alternatives?
I’m not sure about that. It may be. There are certainly benefits to be
derived for MTac and the like, but they may be able to get most of the
way
without solving point 2 above which is the thorny bit.
