- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ways to match in the goal by type?
- Date: Sun, 20 Mar 2016 10:53:39 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f170.google.com
- Ironport-phdr: 9a23:Bb1f4xwfc/TbEoXXCy+O+j09IxM/srCxBDY+r6Qd0e8VIJqq85mqBkHD//Il1AaPBtWLraoVwLqN+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt6U15X8h7v60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGxmkql+rIsYDe26Ivx5HvRkC2EtNHlw78n2vzHCSxGO7z0SSDY4iB1NVirC6hjmXp73+g/3t/Rw3jXSac/xS7E3VDCv4o9kTRbpjGEMMDtvozKfsdB5kK8O+EHpnBd42YOBPdmY
On 03/20/2016 12:52 AM, Jason Gross wrote:
Hi,
I just ran into a tactic that's 20x slower in 8.4 than in 8.4
<https://coq.inria.fr/bugs/show_bug.cgi?id=4630>. Basically the tactic is:
match goal with
| [ |- appcontext[?e] ]
=> not is_var e;
not is_evar e;
match type of e with
| _ <= _ => idtac
end;
generalize e
end
where not is a tactical of my own devising that does the obvious thing.
Is there a better way to do this? One that doesn't require doing stuff with
every single subterm of the goal type?
Thanks,
Jason
I have a similar tactic that wants to examine only subterms of a specific type. The unfortunate thing is that context does not accept type casts - or actually, it does, but does nothing with them. Because it would be nice to be able to do this instead "context[?e : _ <= _]".
I found that rewriting the tactic to avoid using context and instead do recursive descent speeds things up - but this is only worth doing if the goal is limited syntactically somewhat - like without binders, or at least without matches.
However, maybe one can use universes to limit the search? Assuming that "_ <= _" is in Prop, then one can recurse over the goal using set to pull out one context at a time (set would replace it with a var), which is then examined recursively, but only if it is itself a Prop or something that can contain a Prop (not a Set). Hopefully, the slowdown comes from contexts that cannot contain Props.
-- Jonathan
- [Coq-Club] Ways to match in the goal by type?, Jason Gross, 03/20/2016
- Re: [Coq-Club] Ways to match in the goal by type?, Jonathan Leivent, 03/20/2016
