coq-club - [Coq-Club] are type indexes ever necessary?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] are type indexes ever necessary?
  • Date: Mon, 21 Mar 2016 15:03:52 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f41.google.com
  • Ironport-phdr: 9a23:rip07RUtovyv9jiPDshrfUW9LzbV8LGtZVwlr6E/grcLSJyIuqrYZhODt8tkgFKBZ4jH8fUM07OQ6PCwHzVZqs/Y7zgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2DJVwRz2PkPvtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN4xxd7FTDSwnPmYp/4Wr8ECbFUrcrkcbB04Ri1JjBxXPpEXxWY60uS/nvMJ83jObNIv4V+Zndy6l6vJJTxnhlCcOMXYd/WDJh8psxPZZpxSgpBF7zoP8b4ScNf44daTYK4BJDVFdV9pcAnQSSri3aJECWq9YZb5V
Is it true in Coq that any index on an inductive type could *always* be replaced by a type parameter with an extra equality-typed field added to each constructor tying the type parameter to that constructor's value for it?
Except of course for the type eq itself, which needs a type index (because of course one can't define eq using an eq-typed field to replace the index).
For example, fin:
Inductive fin : nat -> Set :=
| Fin1(n : nat) : fin (S n)
| FinS(n : nat) : fin n -> fin (S n).
could be redefined as:
Inductive fin(m : nat) : Set :=
| Fin1(n : nat)(_: m = S n)
| FinS(n : nat)(_: fin n)(_: m = S n).
I keep revisiting this because of various difficulties that type indexes create - such as the need for the inversion tactic, and the corresponding convoy patterns in Gallina match expressions. Also, some tactics, such as case_eq, tend to misbehave when the type has indexes. But, is the claim really true? If not, what is an example where a type index cannot be adequately replaced by a parameter/equality combo?
Defining an inductive type with indexes that vary among the constructors causes case analysis (elimination, destruction, induction) of instances of that type to induce some change to the environment in which the case analysis occurs. If that inductive type is defined with type parameters and equality fields instead, then case analysis does not by itself induce any environment change - that's left for the equality fields - which can then be used only as needed. Hence, there is a better separation of concerns.
There is the extra tedium of always having to fill in the constructors' new equality fields with arguments - but writing "eq_refl" a few times takes no brain power (and could perhaps be automated). Similarly, the equality fields might accumulate in proof mode. But tactics like subst and congruence make that manageable.
-- Jonathan
