- To: coq-club AT inria.fr
- Cc: Theo Giannakopoulos <theo.giannakopoulos AT baesystems.com>
- Subject: [Coq-Club] Change to setoid rewriting over function types in Coq 8.5?
- Date: Fri, 25 Mar 2016 16:37:23 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jwiegley AT gmail.com; spf=Pass smtp.mailfrom=jwiegley AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f181.google.com
- Ironport-phdr: 9a23:NdtQ5xdfUMDcBF9wej2cHojelGMj4u6mDksu8pMizoh2WeGdxc68ZR7h7PlgxGXEQZ/co6odzbGG4+a6ACdZv96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDivceKKFwWzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IeezAcq85Vb1VCig9eyBwvZWz9EqLcQza7XwFF24SjxBgAg7f7Ri8UI2inDH9s783+i6aO4XJTL07XTmzpe8/ShjojjgvMTMm+XvLi9d5irkdqxWk8U8si7XIaZ2YYaItNpjWeskXEC8YBp5c
- Organization: New Artisans LLC
In the code below, that works on Coq 8.4, it fails to rewrite using 8.5, even
though I can apply the morphism proof directly. What has changed to cause
this, and how can I fix it in a way that is compatible with both versions?
Thanks!
John
Require Import Coq.Classes.Morphisms.
Require Import Coq.Setoids.Setoid.
Require Import FunctionalExtensionality.
Definition comp {a b c} (f : b -> c) (g : a -> b) (x : a) : c := f (g x).
Infix "∘" := comp (at level 50).
Corollary f_comp {A B C} (f : B -> C) (g : A -> B) (z : A) :
f (g z) = (f ∘ g) z.
Proof. reflexivity. Qed.
Ltac exploit_identities :=
repeat (match goal with
| [ H : ?F ∘ ?G = id |- context[?F (?G ?X)] ] =>
rewrite (f_comp F), H; clear H
end; unfold id; simpl; auto).
Definition isomorphic (X Y : Type) : Prop :=
exists (f : X -> Y) (g : Y -> X), f ∘ g = id /\ g ∘ f = id.
Infix "≅" := isomorphic (at level 70).
Program Instance Iso_Equivalence : Equivalence isomorphic.
Obligation 1. intro x; do 2 exists id; firstorder. Qed.
Obligation 2. firstorder. Qed.
Obligation 3.
intros x y z H1 H2.
inversion H1 as [f0 H1']; clear H1.
inversion H1' as [f1 H]; clear H1'.
inversion H as [Hf01_id Hf10_id]; clear H.
inversion H2 as [g0 H2']; clear H2.
inversion H2' as [g1 H]; clear H2'.
inversion H as [Hg01_id Hg10_id]; clear H.
exists (g0 ∘ f0).
exists (f1 ∘ g1).
unfold comp.
split; extensionality w;
exploit_identities.
Qed.
Add Parametric Relation {A B : Type} : Type isomorphic
reflexivity proved by (@Equivalence_Reflexive _ _ Iso_Equivalence)
symmetry proved by (@Equivalence_Symmetric _ _ Iso_Equivalence)
transitivity proved by (@Equivalence_Transitive _ _ Iso_Equivalence)
as isomorphic_relation.
Add Parametric Morphism {A} : (Basics.arrow A)
with signature (isomorphic ==> isomorphic)
as fun_ret_isomorphism.
(* isomorphic inputs give isomorphic outputs *)
Proof.
intros.
unfold Basics.arrow.
destruct H as [from_x].
destruct H as [to_x].
destruct H as [from_x0 to_x0].
unfold isomorphic.
exists (fun k a => from_x (k a)).
exists (fun k a => to_x (k a)).
unfold comp.
split;
extensionality k;
extensionality a;
exploit_identities.
Qed.
Lemma f_exp_iso : forall a b c, (b ≅ c) -> ((a -> b) ≅ (a -> c)).
Proof.
intros.
(* exact (fun_ret_isomorphism _ _ _ H). *)
rewrite H.
reflexivity.
Qed.
- [Coq-Club] Change to setoid rewriting over function types in Coq 8.5?, John Wiegley, 03/26/2016
