- From: Pierre Néron <pierre.neron AT polytechnique.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Program and non-exhaustive pattern matching
- Date: Tue, 29 Mar 2016 10:30:34 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.neron AT gmail.com; spf=Pass smtp.mailfrom=pierre.neron AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f42.google.com
- Ironport-phdr: 9a23:AzskURDgTGQ0up1cW3GfUyQJP3N1i/DPJgcQr6AfoPdwSP7/ocbcNUDSrc9gkEXOFd2CrakU26yM7eu4ACQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTnkbrssMWKKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs0MdX38Mny1ughLC6lmuRpb8qDH38Oxwwi6cFdXxSaEoVD+i6aZyVRKujz0IYW1quFrLg9B92foI6CmqoAZyltbZ
Dear Matthieu Thanks for the upcoming patch. Best Pierre On 03/25/2016 01:47 AM, Matthieu Sozeau
wrote:
Dear Pierre,
indeed this is a bug related to universes, introduced in
8.5,
and easy to fix. The fix will be in the upcoming
patch-level
release or the next. One workaround is to explicitly write
match ` x with ... in the term.
Best,
-- Matthieu
On Fri, Mar 18, 2016 at 4:24 PM Arthur Azevedo de
Amorim <arthur.aa AT gmail.com>
wrote:
Hello Pierre,
Your code seems to work under 8.4 (if we replace
Variant with Inductive):
Require Import Program.
Inductive Is_Some {A} : option A -> Prop :=
| Is_some a : Is_Some (Some a).
Program Definition from_Some A (x : option A |
Is_Some x) : A :=
match x with
| (Some a) => a
| None => _
end.
Next Obligation.
apply False_rect. inversion H.
Qed.
From your error message, it seems that you're having
some issue with universe levels. What's interesting is
that, in 8.5, if we write the term that Coq is complaining
about by hand, no error message appears:
Variant Is_Some {A} : option A -> Prop :=
Check (fun A (x : { x : option A | Is_Some x })
=> proj1_sig x).
Em sex, 18 de mar de 2016 às 09:41, Pierre
escreveu:
Hi,I'm trying to use Program to define some kind of non-exhaustive pattern matching. For example I want to define a function from_Some : (x : option A | "is_some x" ) -> A Require Import Program. Variant Is_Some {A} : option A -> Prop := | Is_some a : Is_Some (Some a). Program Definition from_Some A (x : option A | Is_Some x) : A := match x with | (Some a) => a | None => _ end. Next Obligation. apply False_rect. inversion H. Fail Qed. I can't understand why coq fails here with the following message: The command has indeed failed with message: Illegal application: The term "proj1_sig" of type "forall (A : Type) (P : A -> Prop), {x : A | P x} -> A" cannot be applied to the terms "option A" : "Type" "fun x : option A => Is_Some x" : "option A -> Prop" "x" : "{x : option A | Is_Some x}" The 1st term has type "Type@{max(Set, Top.25)}" which should be coercible to "Type@{Coq.Init.Specif.16}". I managed to get around this problem by defining the following function: Program Definition from_Some1 A (x : option A | Is_Some x) : A := (match x as o return Is_Some o -> A with | (Some a) => fun _ => a | None => fun _ => ! end) _. Next Obligation of from_Some1. inversion H. Qed. but I would like to understand why the first definition fails. Thanks in advance -- Pierre. -- P. |
- [Coq-Club] Program and non-exhaustive pattern matching, Pierre Néron, 03/18/2016
- Re: [Coq-Club] Program and non-exhaustive pattern matching, Arthur Azevedo de Amorim, 03/18/2016
- Re: [Coq-Club] Program and non-exhaustive pattern matching, Matthieu Sozeau, 03/25/2016
- Re: [Coq-Club] Program and non-exhaustive pattern matching, Pierre Néron, 03/29/2016
