- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Mu combinator
- Date: Wed, 30 Mar 2016 15:01:21 +0000
- Accept-language: en-US, en-GB
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx02.nottingham.ac.uk
- Ironport-phdr: 9a23:rUFu7RwC1L4G+7rXCy+O+j09IxM/srCxBDY+r6Qd0eIXIJqq85mqBkHD//Il1AaPBtWLragUwLWH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt6U1ZT8iLH60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mooRLVry/dKAlR5RZCi4nOiY7/oej4RLEVE6E4mYWemQQiBtBRQbfukLURJD05xf6sfBmxCScdeTyUb0yWjW45KcjHCPojz0cKzM/tkjTlsF2j6NBqxKJoRtj34/Sb4GcMbx3deXAfoVJFiJ6Qs9NWnkZUcuHZIwVAr9ZMA==
You need a stronger assumption on f to ensure termination because otherwise you could have
f x = x -> x
and this would give you untyped lambda calculus and hence non-termination. First of all you want to eliminate the possibility of negative occurences, I.e. you need to require that f is a functor (you need this anyway even in Haskell if you want to define
the fold for the datatype). However, even this requirement leaves you with some stratnge types which are not definable in Coq, such as
f x = (x -> bool) -> bool
While accepting these sort of types doesn’t directly lead to non-termination they is no goo justification in my view why they should exist. Instead of positivity (withnessed by f being a functor) you want strict positivity which can be witnessed by f being
a container, that is there is
S : Set
P : S -> Set
such that
f x = Sigma s:S. P s -> x
then Mu f exist and it is called a W-type. For more details on containers see for example
or for a more paedagogical introduction, see section 5 of
Thorsten
Reply-To: <coq-club AT inria.fr>
Date: Wed, 30 Mar 2016 16:46:57 +0200
Subject: [Coq-Club] Mu combinator
Hello,I wonder whether it is possible to define the Mu combinator in Coq in a general way.
In Haskell it can be defined like that:>>>newtype Fix f = Fx (f (Fix f ) )<<<Or like that (using records syntax):>>>newtype Mu f = In {out :: f (Mu f)}<<<
When translated directly into Coq it fails with "Non strictly positive occurrence of Mu":>>>Inductive Mu f := MIn {MOut: f ( Mu f) }.<<<
Maybe I need to throw in some axioms to work around the termination issues?
It seems, however, that for an arbitrary recursive type one can always write a definition that corresponds to the Mu application to the corresponding functor:>>>Inductive exprf a :=| add : a -> a -> exprf a| lit: nat -> exprf a.
Inductive expr := In { Out: exprf expr }.<<<
While doing a little research I have only stepped on the work of Arthur Chargueraud (A Practical Fixed Point Combinator for Type Theory), but it does not seem to me that it is relevant.
What I am trying to achieve is the separation of the recursion schema and the computable part (algebra) for catamorphisms and anamorphisms.BRIgor
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it. Please do not use, copy or disclose the information contained in this message or in any attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. This message has been checked for viruses but the contents of an attachment may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Mu combinator, Igor Zhirkov, 03/30/2016
- Re: [Coq-Club] Mu combinator, Thorsten Altenkirch, 03/30/2016
- Re: [Coq-Club] Mu combinator, John Wiegley, 03/30/2016
- Re: [Coq-Club] Mu combinator, Gregory Malecha, 03/31/2016
