coq-club - Re: [Coq-Club] Coq reals as a field instance.
  • From: Frédéric Besson <frederic.besson AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq reals as a field instance.
  • Date: Wed, 6 Apr 2016 10:02:28 +0200
Hi,
Long story short: you have uncovered a problem of psatz - thanks for the bug
report!
revert H0 ; generalize (1/0) ; psatz R 1 does the trick
The problem is that you goal is not syntactically linear.
psatz tries to linearise goals by reconstructing rational constants.
My guess is that it fails because of the division by zero - I would need to
investigate further...
Here, it should not produce a partial proof term but really fail— there is an
unfortunate try in the tactic.
Best,
Frédéric
> On 05 Apr 2016, at 06:00, Burak Ekici
> <ekcburak AT hotmail.com>
> wrote:
> Hi all,
> I've been trying to prove Coq reals as an algebraic field instance.
> Please find my code here:
> https://github.com/ekiciburak/algebraic-groups-fields/blob/master/algebraic_groups_fields.v
> Considering the last instance (at line 128):
> "Program Instance field_reals: `(@field R (Req_setoid) _ rmult _ rid2 _
> rinv2 group_reals)."
> I was not able to prove the below obligation (at line 132):
> "Obligation 4 of field_reals:
> forall a : R, a == rid -> rmult (rinv2 a) a == rid2 -> False."
> This basically looks like
> 1 subgoals
> H0 : 1 / 0 * 0 = 1
> ______________________________________(1/1)
> False
> after unfolds. When to say "revert H0; psatz R 1.", Coq does not
> complain, but it is not happy either; I'm getting something like
> 1 subgoals
> let __wit := nil in
> let __varmap := VarMap.Empty R in
> let __ff :=
> Tauto.I
> (Tauto.A
> Flhs := EnvRing.PEc
> (RMicromega.CMult
> (RMicromega.CMult RMicromega.C1
> (RMicromega.CInv RMicromega.C0)) RMicromega.C0);
> Fop := OpEq;
> Frhs := EnvRing.PEc RMicromega.C1 |})
> (Tauto.FF (Formula RMicromega.Rcst)) in
> 1 / 0 * 0 = 1 -> False.
> I guess, this is because there is no witness for "psatz R 1" but I don't
> know how to provide one.
> I'd be more than appreciated if you could point me a way to get around
> it. The problem might be a consequence of the way that I've
> implemented things?
> Many thanks in advance!
> Best,
> Burak.
