- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: "coq-club AT inria.fr Club" <coq-club AT inria.fr>
- Subject: [Coq-Club] Looking for alternative to a non-terminating conversion
- Date: Thu, 7 Apr 2016 14:41:42 +0200
Hi all,
I am puzzled by the behaviour of the change tactics.
I hope that someone can enlighten me.
My problem is that I have a conversion that does not terminate.
I am in the context of an automatic tactic
and I would like to have a robust (and fast) alternative.
Consider the following:
* change term (* Takes forever. Fine, probably this is sometimes unavoidable.
* change_no_check term;
(* bound to Tactics.convert_concl_no_check (snd term) DEFAULTcast
which performs a change blindly without checking that terms are
convertible
tac.
Time Qed. (* Finished transaction in 0.012 secs (0.012u,0.s) (successful)*)
Is-it always a sound course of action to wrap an « abstract » around a tactic
and perform conversion without check within the tactic ?
* match goal with
| |- ?X => replace X with term by reflexivity
end; (* Is instantaneous *)
tac.
Time Qed. (*Finished transaction in 0.015 secs (0.015u,0.s) (successful) *)
Is-it a safer path to insert an explicit equality at the cost of a slightly
bigger term ?
What do you think ?
Thanks,
Frédéric
- [Coq-Club] Looking for alternative to a non-terminating conversion, Frédéric Besson, 04/07/2016
