coq-club - Re: [Coq-Club] Tactic Notation and lists
  • From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Tactic Notation and lists
  • Date: Tue, 12 Apr 2016 14:24:57 +0200
On 12/04/2016 14:16, Robbert Krebbers wrote:
> Can you give us some idea of the "global picture" that you are after?
Turn Ltac into a mini-ML with backtracking as the built-in effect?
That requires a few things, amongst which:
1. Stick to a proper calling convention (namely CBV)
2. Clearly separate syntax from semantics (mostly already done in trunk)
3. Add datatypes (the semantics is already there, we essentially need a
syntax)
We could probably add
4. Add a typing system
but I'm afraid that this one is too backward-incompatible. Point 1 is
going to break things, while 2 and 3 are mostly backward-compatible.
There are some blocking points regarding compatibility that impede a
real progress, but I am close to being able to provide Ltac as a plugin,
so that one could separate the version of Ltac from the one of Coq, and
dynamically change the version of the language used.
PMP
Attachment: signature.asc
Description: OpenPGP digital signature
