coq-club - [Coq-Club] Problem with Coq, Index and Parameter types.
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Problem with Coq, Index and Parameter types.
  • Date: Mon, 11 Apr 2016 16:03:26 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tyr.god.of.war42 AT gmail.com; spf=Pass smtp.mailfrom=tyr.god.of.war42 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ig0-f170.google.com
  • Ironport-phdr: 9a23:0h4XexRBB4nvIkPvSMPDvkbST9psv+yvbD5Q0YIujvd0So/mwa64YBSN2/xhgRfzUJnB7Loc0qyN4/CmBT1LuMrY+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq82VP1QD3WbkKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxyZIDg+Nxhz+V5brv2Ouqupw32+QMMn/TKo5cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hello, I have a problem relating to index vs parameterized types.
Here is the full source code, and the line where everything goes wrong.
https://github.com/tbelaire/FJ-Formalization/blob/wip/FJ_Definitions.v#L1326
I am working on a variant of Feather Weight Java, and the key types are ctable as a list  [(Child_class, (Parent_class, fields, methods))].
I'm trying to prove some things about subsets and strict subsets.
The definition
Inductive ssub_ (CT:ctable) : typ -> typ -> Prop :=
| ssub_trans : forall t1 t2 t3,
    ssub_ CT t1 t2 ->
    ssub_ CT t2 t3 ->
    ssub_ CT t1 t3
| ssub_extends : forall t1 t2, extends_ CT t1 t2 -> ssub_ CT t1 t2.
generates the inductive principle:
ssub__ind :
  forall (CT : ctable) (P : typ -> typ -> Prop),
 (forall t1 t2 t3 : typ,
ssub_ CT t1 t2 -> P t1 t2 -> ssub_ CT t2 t3 -> P t2 t3 -> P t1 t3) ->
 (forall t1 t2 : cname, extends_ CT t1 t2 -> P t1 t2) ->
forall C D : typ, ssub_ CT C D -> P C D
but in my particular case I'm trying to apply it:
I need to have CT instantiated with (C, (F, fs2, ms2)) :: CT, which references C,
before I do the forall, causing the forall to generate a fresh variable C0, and get my proof to become stuck,
as the C referenced in P C D isn't the same as the C in the class table that it also mentions.
I do not know how to solve it, since changing the definition to:
Inductive ssub_ : ctable -> typ -> typ -> Prop :=
| ssub_trans : forall CT t1 t2 t3,
        ssub_ CT t1 t2 ->
        ssub_ CT t2 t3 ->
        ssub_ CT t1 t3
| ssub_extends : forall CT t1 t2, extends_ CT t1 t2 -> ssub_ CT t1 t2.
is causing my more problems in my existing proofs, where induction on
H_sub: ssub_ (A, (B, fs, ms)) ::CT C D just throws out the information about A and B,
as the induction wants to be forall CTs, not just ones with A and B in front.
I have proven the old (parametric) induction principle in terms of the new (indexed) one,
and if it's possible to even just go `induction H_sub using ssub__ind_old.` to get the old
behaviour instead of needing to use `refine` to get it to work, that would be quite helpful.
  • [Coq-Club] Problem with Coq, Index and Parameter types., Theo Belaire, 04/11/2016
