coq-club - Re: [Coq-Club] How to get a constr_expr?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to get a constr_expr?
  • Date: Wed, 13 Apr 2016 11:14:50 -0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bziliani AT famaf.unc.edu.ar; spf=None smtp.mailfrom=bziliani AT famaf.unc.edu.ar; spf=None smtp.helo=postmaster AT famaf.unc.edu.ar
  • Ironport-phdr: 9a23:3dnqTx09bS6ajEk3smDT+DRfVm0co7zxezQtwd8ZsegRLvad9pjvdHbS+e9qxAeQG96Lu7QZ0KGI7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZnsnL7vs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjN92Mq+nh7aBSCL+3FUBm4Ri19DBxXPxBD8RJb49CXg4LlTwi6faOf7Ubl8azWm7q5tSVe8gjUGMz8w9mD/hMV1hawdvRSq4RFz3sjdetfGZ7JFYqrBcIZCFiJ6VcFLWnkEW9vkYg==
On Wed, Apr 13, 2016 at 11:04 AM, Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr> wrote:
On 13/04/2016 15:33, Beta Ziliani wrote:
> Actually, I think what I need is an open_constr. Now the question is,
> what do I do with the sigmas? I get one from the goal, and one for each
> open_constr, which one should I use, or how should I combined them?
You're using 8.5 I believe? This open_constr API is quite broken and is
a source of evar leaks, but there is nothing better in that version.
AFAIR, the sigma you get in the open_constr argument is an extension of
the one of the goal, so that you can discard the latter...
Mmm... Not quite. I have two open_constrs c and c' with sigmas s and s'. It looks like in s there are no evars from c' and viceversa :-(
PMP
