Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities
- Date: Wed, 13 Apr 2016 23:59:44 +0200
Not that I remember of, but calling ring with the equations x * x = x
for all the boolean variables of your expression should do the trick.
Oops you should also add 2*x = 0.
- Laurent
- [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Abhishek Anand, 04/13/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Laurent Thery, 04/13/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Abhishek Anand, 04/15/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Daniel Schepler, 04/15/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Pierre-Marie Pédrot, 04/15/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Laurent Thery, 04/15/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Abhishek Anand, 04/16/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Daniel Schepler, 04/16/2016
- Re: [Coq-Club] ring tactic: boolean rings and completeness when supplied with equalities, Assia Mahboubi, 04/19/2016
