- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] inversion of an inductive
- Date: Fri, 15 Apr 2016 22:44:41 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT imag.fr; spf=Neutral smtp.mailfrom=jean-francois.monin AT imag.fr; spf=None smtp.helo=postmaster AT amazone.ujf-grenoble.fr
- Ironport-phdr: 9a23:4L+UBB2g30tqHbkTsmDT+DRfVm0co7zxezQtwd8ZsegTKPad9pjvdHbS+e9qxAeQG96Lu7QZ1KGM4/6ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC34LqiKvoq8ObSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7axHYVVCA4iBNOCA/E91nfWZHwtGOutOd03myUJ8TwRrc1QnKn6KFqTjfpjS4IcTAjpjKEwvdshb5W9Ury7yd0xJTZNdmY
Hi Pierre,
You can use the generalization of "small inversions" explained in
http://www-verimag.imag.fr/~monin/Publis/Docs/itp13.pdf
It can handle (co)inductive with several (0 or 1, in your case) premises.
Here you can invert UassignLeaf and UassignNode using the same auxiliary
function.
Definition pr_Uassign {s} {a} {u} (x: Uassign s a u) :=
let diag s a0 u0 :=
match s with
| << f >> =>
forall X: Agent -> Utility -> Prop,
(forall a, X a (f a)) -> X a0 u0
| << a' , c , next >> =>
(forall a u, Uassign (next c) a u -> X a u) -> X a0 u0
end in
match x in Uassign s a u return diag s a u with
| UassignLeaf a f => fun X k => k a
| UassignNode a a' c ut next ua => fun X k => k a ut ua
end.
Lemma UassignNode_inv:
forall (a a':Agent) (u:Utility) (next:Choice a' -> StratProf) (c:Choice
a'),
Uassign (<<a',c,next>>) a u -> Uassign (next c) a u.
intros until c. intro ua. apply (pr_Uassign ua). trivial.
Qed.
Lemma UassignLeaf_inv:
forall (a:Agent) f (u:Utility), Uassign << f >> a u -> u = f a.
intros a f u ua. apply (pr_Uassign ua). trivial.
Qed.
Cheers,
Jean-Francois
On Fri, Apr 15, 2016 at 07:37:30PM +0200, Pierre Lescanne (at work) wrote:
> I have developed in Coq exercises in extensive game theory (for
> economics). A first development was with coinductive. In this
> development I was able to perform inversion.
> Now I generalize the approach and I describe a slightly more elaborate
> formalism with dependent types and I am no more able to perform
> inversion. Is such an inversion possible in this framework?
> Here is the script I am stuck on.
> Section Games.
> Variable Agent : Set.
> Variable Choice : Agent -> Set.
> Variable Utility: Set.
> (* Strategy profiles *)
> CoInductive StratProf : Set :=
> | sLeaf : (Agent -> Utility) -> StratProf
> | sNode : forall (a:Agent), Choice a -> (Choice a -> StratProf) ->
> StratProf.
> Notation "<< f >>" := (sLeaf f).
> Notation "<< a , c , next >>" := (sNode a c next).
> (* Utility assignment as a relation*)
> Inductive Uassign : StratProf -> Agent -> Utility -> Prop :=
> | UassignLeaf: forall a f, Uassign (<<f>>) a (f a)
> | UassignNode: forall (a a':Agent)(c:Choice a') (u:Utility) (next:Choice
> a' -> StratProf),
> Uassign (next c) a u -> Uassign (<<a',c,next>>) a u.
> Lemma UassignNode_inv: forall (a a':Agent) (u:Utility)
> (c:Choice a'),
> Thank you in advance
> Pierre Lescanne (Emeritus Professor)
> LIP / École normale supérieure de Lyon
> 46 allée d'Italie
> 69364 LYON Cedex 07, France
> tél: +33 6 85 70 94 31
> [1]http://perso.ens-lyon.fr/pierre.lescanne/
- [Coq-Club] inversion of an inductive, Pierre Lescanne (at work), 04/15/2016
- Re: [Coq-Club] inversion of an inductive, Adam Chlipala, 04/15/2016
- Re: [Coq-Club] inversion of an inductive, Jean-Francois Monin, 04/15/2016
- Re: [Coq-Club] inversion of an inductive, Pierre Lescanne (at work), 04/16/2016
