coq-club - Re: [Coq-Club] How can I make proofs from Standard Library transparent?
  • From: e+coq-club AT x80.org (Emilio Jesús Gallego Arias)
  • To: Ilmārs Cīrulis <ilmars.cirulis AT gmail.com>
  • Cc: "coq-club\@inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How can I make proofs from Standard Library transparent?
  • Date: Fri, 22 Apr 2016 15:47:03 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=e+coq-club AT x80.org; spf=Neutral smtp.mailfrom=e+coq-club AT x80.org; spf=None smtp.helo=postmaster AT boipeva.ensmp.fr
  • Ironport-phdr: 9a23:dfS3zxxihsJ8gJ3XCy+O+j09IxM/srCxBDY+r6Qd0eMSIJqq85mqBkHD//Il1AaPBtWLra0cwLSH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt6U0Jz8ibH60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jKsRxoVxC4zXoGT2EXiVIcAgzA5QvhGJzwqDb+t/FV1yyTPMmwRrcxD2eM9aBuHRKrgyAecjU97Wv/mpwoyqVBr1rhihl+x4/TKKOYL2hlNozUedcXSm0Jd9xQXjcAUdD0VJcGE+dUZbUQlIL6vVZb6ELmXQQ=
  • Organization: X80 Heavy Industries
Hi Ilmārs,
there's two kind of standard workarounds to this problem (apart from
making proofs transparent and being smarter in definitions). Both of
them involve changing your list definition:
- Use list T n ≡ { s : list T | length s = n }
You'll also need to prove proof irrelevance on the proof, so it is a
good idea to use decidable predicates, see ssreflect tuple.v for an
example of this.
- Use list T n := fix V n := match n with | 0 => unit | S n => T * V n
Hope it helps.
E.
Ilmārs Cīrulis
writes:
>> Can you give some code here please? I don't see what transparency can
> help here.
> Pierre, here is a code example.
> Require Import Utf8 Arith.
> Set Implicit Arguments.
> Inductive list A: nat → Type :=
> | nil: list A 0
> | cons: ∀ n, A → list A n → list A (S n).
> Arguments nil [A].
> Infix "::" := cons (at level 60, right associativity).
> Fixpoint app A n m (L: list A n) (L0: list A m): list A (n + m) :=
> match L with
> | nil => L0
> | a :: t => a :: app t L0
> end.
> Infix "++" := app (at level 60, right associativity).
> Definition add_to_end A n (L: list A n) (x: A): list A (S n) :=
> eq_rect _ _ (L ++ x :: nil) _ ltac:(rewrite plus_comm, plus_n_O; auto).
> Eval compute in (add_to_end nil 1).
> = match
> match
> match Nat.add_comm 0 1 in (_ = y) return (y = 1) with
> | eq_refl => eq_refl
> end in (_ = y) return (y = 1)
> with
> | eq_refl =>
> match match plus_n_O 1 in (_ = y) return (y = 1) with
> | eq_refl => eq_refl
> end in (_ = y) return (1 = y) with
> | eq_refl => plus_n_O 1
> end
> end in (_ = y) return (list nat y)
> with
> | eq_refl => 1 :: nil
> end
> : list nat 1
>> If the inductive proof of n + 1 = S n is Qeded, then you cannot reduce it
> in proof terms using it, I think that's what Ilmārs is saying. There's
> currently no getting around reproving it transparently.
> Matthie, it must be this.
> I'm using Coq for fun and experience, so learning vocabulary and theory
> isn't in the first place. Probably not for good.
> Thank you.
> On Fri, Apr 22, 2016 at 2:59 PM, Matthieu Sozeau
> <mattam AT mattam.org>
>> -- Matthieu
>> Le ven. 22 avr. 2016 à 13:55, Pierre Courtieu
>> <pierre.courtieu AT gmail.com>
>> a écrit :
>>> 2016-04-22 0:32 GMT+02:00 Ilmārs Cīrulis
>>> <ilmars.cirulis AT gmail.com>:
>>> > Probably I can't. They're opaque and that's all.
>>> I am afraid so.
>>> > I need them, for example, to prove that types list A (n + 1) and list A
>>> (S
>>> > n) are equal and then use this equality in computations.
>>> I don't understand, an equality cannot help "computation" as far as I
>>> can tell. You mean that this equality allows to rewrite *and then* you
>>> can compute right? But then the transparency is not the problem.
>>> > For now I just prove necessary equality again, this time transparently.
>>> help here.
>>> Best
>>> Pierre Courtieu
