- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] merging functions over disjoint domains
- Date: Wed, 27 Apr 2016 19:48:38 +0200
On 27/04/2016 19:28, Jonas Oberhauser wrote:
>>> Are there better solutions, in particular ones that do not need
>>> decidability of P?
>> Certainly not without the decidability of P. Think about the following
>> type:
>> Inductive X : M -> Type :=
>> | X0 : forall n, P n -> X n
>> | X1 : forall n, not (P n) -> X n.
>> By taking f and f' as identity functions, you get a way to decide P if
>> you have a way to define (merge f f').
> I'm not sure I follow. What are the types of f and f'? By identities,
> do you mean (fun n => n)? I can not merge these since they have the same
> domain (domains have to be disjoint) or different codomains.
> If I would merge X0 and X1 I would expect to obtain a function forall n,
> P n \/ not (P n) -> X n, which should not give me a decider for P unless
> I already work classically.
You are mixing two kinds of decidability here. (I don't know if there is
a better way to name them.) One is the excluded-middle property and the
other is the existence of an algorithm. Here is a Coq script to make it
clearer:
Parameter M : Type.
Definition merge {X} {P P' : M -> Prop} (f : forall n, P n -> X n)
(f' : forall n, P' n -> X n) : forall n, P n \/ P' n -> X n.
Admitted.
Parameter P : M -> Prop.
Lemma foo : forall n, P n \/ not (P n) -> {P n} + {not (P n)}.
Proof.
intros n H.
apply (merge X0 X1 n) in H.
now destruct H as [H|H] ; [left|right].
Qed.
Best regards,
Guillaume
- [Coq-Club] merging functions over disjoint domains, Jonas Oberhauser, 04/26/2016
- Re: [Coq-Club] merging functions over disjoint domains, Guillaume Melquiond, 04/26/2016
- Re: [Coq-Club] merging functions over disjoint domains, Jonas Oberhauser, 04/27/2016
- Re: [Coq-Club] merging functions over disjoint domains, Guillaume Melquiond, 04/27/2016
- Re: [Coq-Club] merging functions over disjoint domains, Abhishek Anand, 04/27/2016
