- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Examples in Mike Nahas's tutorial
- Date: Thu, 28 Apr 2016 16:21:23 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabriel.scherer AT gmail.com; spf=Pass smtp.mailfrom=gabriel.scherer AT gmail.com; spf=None smtp.helo=postmaster AT mail-ig0-f174.google.com
- Ironport-phdr: 9a23:xLHJuhf0kBenBqZamXt1FUyAlGMj4u6mDksu8pMizoh2WeGdxc69bR7h7PlgxGXEQZ/co6odzbGG4+awBSdZvcjJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviq9uDP04R2GT1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S43VXxeuR5VCUCR5xbjG5z1ryHSt+xn2SDcM9egHp4uXjH3wK5hUh7ljG88PD406mzNwph/hahBoR+l4Qd0w4PObZu9O/93f6ebdtQfEzkSFv1NXjBMV9vvJ7AECPAMaKMB99Hw
On my machine, the code in your email works fine if I *prefix* it by
the following:
Set Implicit Arguments.
Definition Is_true (b : bool) : Prop :=
match b with
| true => True
| false => False
end.
On Thu, Apr 28, 2016 at 3:40 PM, Hussain Sobhy
<hussain.sob7y AT gmail.com>
wrote:
> Thanks for the clarification.
> But is the code in the tutorial correct? I can't seem to get it working in
> an implicit or explicit setting.
> On Thu, Apr 28, 2016 at 7:04 PM, Gabriel Scherer
> wrote:
>> The arguments of the constructor may also include the parameters of
>> the type itself.
>> Check @ex_intro.
>> > ex_intro : forall (A : Type) (P : A -> Prop) (x : A), P x -> exists x, P
>> > x
>> A can be easily inferred as it is completely determined by the types
>> of P and x. On the contrary, P is harder to infer from the other
>> parameters (and I don't know whether Coq can reason about how to
>> extract if from (exists x, P x). With the common default settings of
>> implicit arguments, A will be considered implicit and P, x and (_ : P
>> x) will not.
>> Note that the syntax (A := A) in the ex declaration code you used only
>> makes sense when the A parameter is implicit.
>> On Thu, Apr 28, 2016 at 1:33 PM, Hussain Sobhy
>> wrote:
>> > Further down in the tutorial, there's this example:
>> > Inductive ex (A:Type) (P:A -> Prop) : Prop :=
>> > ex_intro : forall x:A, P x -> ex (A:=A) P.
>> > Notation "'exists' x .. y , p" := (ex (fun x => .. (ex (fun y => p))
>> > (at level 200, x binder, right associativity,
>> > format "'[' 'exists' '/ ' x .. y , '/ ' p ']'")
>> > : type_scope.
>> > Definition basic_predicate
>> > (fun a => Is_true (andb a true))
>> > Theorem thm_exists_basics : (ex basic_predicate).
>> > Proof.
>> > pose (witness := true).
>> > refine (ex_intro basic_predicate witness _).
>> > simpl.
>> > exact I.
>> > Qed.
>> > The code as is produces the following error:
>> > Error:
>> > Illegal application (Non-functional construction):
>> > The expression
>> > "ex_intro basic_predicate witness"
>> > of type "exists x, ?P x"
>> > cannot be applied to the term
>> > "?y" : "?T"
>> > I don't actually understand why Mike expects ex_intro to take 3
>> > arguments.
>> > From what I understand it should take 2 arguments or even 1.
>> > Can someone point out what's wrong here?
>> > Thanks,
>> > Hussain
>> > On Thu, Apr 28, 2016 at 12:19 AM, Hussain Sobhy
>> > wrote:
>> >> Thanks Gabriel for the clarification. This is very useful.
>> >> Regards,
>> >> Hussain
>> >> On Wed, Apr 27, 2016 at 11:41 PM, Gabriel Scherer
>> >> wrote:
>> >>> The difference in behavior comes from implicit arguments. Formally
>> >>> or_introl or or_introl each take three arguments: the propositions A
>> >>> and B, and the constructor parameter.
>> >>> Check (@or_introl True False I)
>> >>> The syntax @or_introl lets me use the or_introl identifier with no
>> >>> implicit argument at all.
>> >>> In the book, or_introl and or_introl are considered to have their two
>> >>> first parameters implicit. The failure that you show comes from the
>> >>> fact that, on your machine, the parameters are not implicit. So
>> >>> (or_introl) expects a proposition as first parameter, not a proof of
>> >>> that proposition.
>> >>> You can make the code pass unchanged by setting the following options
>> >>> before it:
>> >>> Set Contextual Implicit.
>> >>> Inductive or (A B:Prop) : Prop :=
>> >>> | or_introl : A -> A \/ B
>> >>> | or_intror : B -> A \/ B
>> >>> where "A \/ B" := (or A B) : type_scope.
>> >>> You will find documentation on implicit arguments in the manual,
>> >>> https://coq.inria.fr/refman/Reference-Manual004.html#Implicit%20Arguments
>> >>> Note that the explicit arguments that you get depend on whether you
>> >>> use the "or" type defined in the standard library, or if you redefine
>> >>> your own as you show in your email. If you use the standard one, you
>> >>> get the setting for implicit arguments that was decided in the
>> >>> standard library code, and the example proofs work unchanged. You only
>> >>> need those options if you redefine your own "or" type as you show in
>> >>> your email, so that the implicit arguments are chosen in a way similar
>> >>> to what the standard library does.
>> >>> Another option is to manually set the implicit arguments of the
>> >>> constructors, instead of a general setting
>> >>> Arguments or_introl [A B] _.
>> >>> Arguments or_intror [A B] _.
>> >>> On Wed, Apr 27, 2016 at 6:08 PM, Hussain Sobhy
>> >>> wrote:
>> >>> > Hello,
>> >>> > I was going through Mike Nahas's tutorial
>> >>> > (https://coq.inria.fr/tutorial-nahas) and I came across two examples
>> >>> > which I
>> >>> > can't get working on CoqIde.
>> >>> > First Example:
>> >>> > Theorem left_or : (forall A B : Prop, A -> A \/ B).
>> >>> > Proof.
>> >>> > intros A B.
>> >>> > intros proof_of_A.
>> >>> > pose (proof_of_A_or_B := or_introl proof_of_A : A \/ B).
>> >>> > exact proof_of_A_or_B.
>> >>> > Qed.
>> >>> > Error:
>> >>> > In environment
>> >>> > A, B : Prop
>> >>> > proof_of_A : A
>> >>> > The term "proof_of_A" has type "A"
>> >>> > while it is expected to have type
>> >>> > "Prop".
>> >>> > Second Example:
>> >>> > Theorem right_or : (forall A B : Prop, B -> A \/ B).
>> >>> > Proof.
>> >>> > intros A B.
>> >>> > intros proof_of_B.
>> >>> > refine (or_intror _).
>> >>> > exact proof_of_B.
>> >>> > Qed.
>> >>> > Error:
>> >>> > In environment
>> >>> > A, B : Prop
>> >>> > proof_of_B : B
>> >>> > The term "or_intror ?P" has type
>> >>> > "forall B0 : Prop, B0 -> ?P \/ B0"
>> >>> > "A \/ B".
>> >>> > Is it due to the fact that the tutorial used an old version of Coq
>> >>> > or
>> >>> > is
>> >>> > there something fundamentally wrong here?
>> >>> > Thanks,
>> >>> > Hussain
- [Coq-Club] Examples in Mike Nahas's tutorial, Hussain Sobhy, 04/28/2016
- Re: [Coq-Club] Examples in Mike Nahas's tutorial, Gabriel Scherer, 04/28/2016
- Re: [Coq-Club] Examples in Mike Nahas's tutorial, Hussain Sobhy, 04/28/2016
- Re: [Coq-Club] Examples in Mike Nahas's tutorial, Hussain Sobhy, 04/29/2016
- Re: [Coq-Club] Examples in Mike Nahas's tutorial, Igor Zhirkov, 04/29/2016
