[Coq-Club] Resolving ambiguity between multiple notations for a single identifier
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Resolving ambiguity between multiple notations for a single identifier
- Date: Sat, 30 Apr 2016 15:11:31 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:SHjHGxV2p6a7cTukx4dU1Sl7JSnV8LGtZVwlr6E/grcLSJyIuqrYZheAt8tkgFKBZ4jH8fUM07OQ6PCwHzxQqs/b7zgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2DJVUYz2PnPvtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzM/dmsx+cfDtB/ZTALJ6GFPfH8Rl09TCA/Z8FnxWZHqriLwsuc1jDKWNsrwVqw9cS+z9eFmRAK+23RPDCIw7GyC0p84t6lcuh/0/xE=
Hi All,
The reference manual gives a terrific explanation of how Coq resolves ambiguity in the mapping from notation to identifier via the scope stack. However, I can't seem to find an explanation on how Coq resolves ambiguity in the mapping from identifier to notation when displaying symbolic notations (one might expect such an explanation in Section 12.1.5 of the manual). For instance,
Require Import Bool.
Definition my_b := andb true false.
Infix "+" := andb.
Print my_b.
(* At this point, andb has two notations: "+" and "&&". How does Coq choose which to display? Once I have defined the "+" notation, can I go back to using "&&"? *)
Thanks in advance,
~Scott Constable
- [Coq-Club] Resolving ambiguity between multiple notations for a single identifier, scott constable, 04/30/2016
- Re: [Coq-Club] Resolving ambiguity between multiple notations for a single identifier, Jonathan Leivent, 04/30/2016
