- To: coq-club AT inria.fr
- Subject: [Coq-Club] Matching function applications in second-order patterns
- Date: Sat, 14 May 2016 07:23:36 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=wilcoxjay AT gmail.com; spf=Pass smtp.mailfrom=wilcoxjay AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f49.google.com
- Ironport-phdr: 9a23:rfeQ1BYEwBOv0i8/L2ymlhb/LSx+4OfEezUN459isYplN5qZpc+/bnLW6fgltlLVR4KTs6sC0LqH9fq7EjJaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0ocaYPV8ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JcGwTnwEAPAnB5xbqFsPusy/xsfp/0TiyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
I am trying to use second-order ltac patterns to implement a reflection tactic that can recurse under binders, roughly following the strategy outlined in the CPDT chapter on reflection. I can't figure out how to write a second-order pattern that matches a function application.
For example, I would expect to be able to write something like
Ltac reflect x :=
match eval simpl in x with
(* other cases here *)
| fun (y : ?T) => (@?F y) (@?A y) => (* ... *)
end.
Coq accepts this definition syntactically, but whenever the case matches, it complains "Only bound indices allowed in second order pattern matching."
The closest I can get to something like this working is to disallow references to bound variables in the left hand side of the application, as follows:
fun (y : ?T) => ?F (@?A y) => (* ... *)
This works as long as the tactic never encounters a function application that applies an _expression_ that refers to bound variables, but this is not as general as I'd like.
Does anyone know if there is a way to do this? I've included a complete but simple example showing the issue below.
James
Example:
The goal is to write a tactic that annotates every function application with the function apply, defined as:
Definition apply {A B} (f : A -> B) (x : A) : B := f x.
A version of the desired tactic with the limitations mentioned above is:
Ltac refl' x :=
lazymatch eval simpl in x with
| fun x => snd (@?B x) => let r := refl' B in constr:(fun z => snd (r z))
| fun x => fst (@?B x) => let r := refl' B in constr:(fun z => fst (r z))
| fun (x : ?T) => x => constr:(fun (z : T) => z)
| fun (y : ?T) (z : ?U) => @?B y z =>
let r := refl' (fun (p : T * U) => B (fst p) (snd p)) in
constr:(fun (y : T) (z : U) => r (y, z))
| fun (y : ?T) => ?F (@?A y) => let r1 := refl' (fun _ : T => F) in
let r2 := refl' A in
constr:(fun y : T => @apply _ _ (r1 y) (r2 y))
| fun (_ : ?T) => ?B => constr:(fun (_ : T) => B)
end.
(* simple driver tactic to print the simplified term constructed by refl' *)
Ltac refl x :=
let r := refl' (fun _ : unit => x) in
let r' := eval simpl in (r tt) in
idtac r'.
For example, it is able to handle the following simple case:
Goal False.
refl (fun (x : nat) (f : nat -> nat) => S x).
(* prints: (fun (x : nat) (_ : nat -> nat) => apply S x) *)
But of course it doesn't work if the _expression_ being applied refers to bound variables:
Goal False.
refl (fun (x : nat) (f : nat -> nat) => f x).
(* Error: Ltac variable F depends on pattern variable name y
which is not bound in current context. *)
Is it possible to implement a version of refl' which handles this case?
- [Coq-Club] Matching function applications in second-order patterns, James Wilcox, 05/14/2016
- Re: [Coq-Club] Matching function applications in second-order patterns, Guillaume Melquiond, 05/14/2016
- Re: [Coq-Club] Matching function applications in second-order patterns, James Wilcox, 05/14/2016
