coq-club - [Coq-Club] Intuition tactic sometimes runs very slow
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Intuition tactic sometimes runs very slow
  • Date: Mon, 23 May 2016 11:34:57 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
  • Ironport-phdr: 9a23:rbeR5xyryKwg+5XXCy+O+j09IxM/srCxBDY+r6Qd0ekRIJqq85mqBkHD//Il1AaPBtWKrakVwLOM6ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6DyZ/mnLnoodX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6U7XwATi0dlRxTHwHP6ByyCoz9uSz8rfZ08DKLJ4v7Qa1iCmfq1LtiVBK90HRPDDU+6myC0sE=
Hi All,
On my latest project, I have noticed that the intuition tactic can sometimes run for an extraordinary amount of time, for instance 26 seconds in the worst case. I can't seem to replicate this behavior with a small example. The project in which I'm noticing the slowdown is roughly 2000 LoC. Is this the expected behavior for the intuition tactic? And what might be causing this?
Thanks in advance,
~Scott Constable
