coq-club - Re: [Coq-Club] Proof irrelevant Specif?
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proof irrelevant Specif?
  • Date: Sat, 28 May 2016 01:39:47 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
  • Ironport-phdr: 9a23:Zh7pzhLBigehVmS/LdmcpTZWNBhigK39O0sv0rFitYgUL/3xwZ3uMQTl6Ol3ixeRBMOAu6MC17ud6fyocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC3oLrhqvop9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF614XEWX38K2jlSDgLP4QvhFsP0uyr+t+xy3CiBIdbeV7c+Uzm486RxRRXihT0ccTg9pjKEwvdshb5W9Ury7yd0xJTZNdmY
Hi Fred,
in this case you are lucky: the proposition <= is proof irrelevant, i.e. any two proofs p,q : x <= y are provably equal. To that end, you can prove (without having to assume proof irrelevance):
coord, c1 = c2 <-> proj1_sig c1 = proj1_sig c2.
See below for a proof.
An alternative is to encode your type as:
{ x | Is_true (b x) }
where b : nat -> bool is a boolean predicate. It is trivial to show that Is_true is proof irrelevant, and thus to prove a property as above.
Robbert
Require Import Eqdep Eqdep_dec Omega.
Lemma nat_le_pi: forall (x y : nat) (p q : x <= y), p = q.
Proof.
assert (forall x y (p : x <= y) y' (q : x <= y'),
y = y' -> eq_dep nat (le x) y p y' q) as aux.
{ fix 3. intros x ? [|y p] ? [|y' q].
- easy.
- clear nat_le_pi. omega.
- injection 1. intros Hy. now case (nat_le_pi x y p y' q Hy). }
intros x y p q. now apply (eq_dep_eq_dec eq_nat_dec), aux.
Qed.
Definition coord := { x | x>0 /\ x <= 3}.
Lemma coord_eq : forall c1 c2 : coord, c1 = c2 <-> proj1_sig c1 = proj1_sig c2.
Proof.
intros c1 c2; split; [now intros ->|].
destruct c1 as [x [Hx Hx']], c2 as [y [Hy Hy']]; simpl; intros ->.
f_equal; f_equal; apply nat_le_pi.
Qed.
Print Assumptions coord_eq.
(* Closed under the global context *)
On 05/28/2016 01:24 AM, Fred Smith wrote:
Hi all,
I wanted to define a small range of numbers and thought this would be a
clean solution:
Then I can define the 3 valid coordinates:
Definition c1 : coord := coord1.
refine (exist _ 1 _).
lia.
Defined.
Definition c2 : coord.
refine (exist _ 2 _).
lia.
Defined.
Definition c3 : coord.
refine (exist _ 3 _).
lia.
Defined.
Now I would like to prove:
Lemma coord_all_wish:
forall c:coord, c=c1 \/ c=c2 \/ c=c3.
Of course this statement is not true, because there are an infinite
number of proofs that c1 satisfies the specification. What I really
mean is proj1_sig c = proj1_sig c1, ...
I was originally viewing this coord type as morally equivalent to the
inductive type c1 | c2 | c3 but with the added benefit that I could make
3 a parameter n and the design would scale. Now, I see that using this
design makes "forall" arguments about coordinates quite painful because
it precludes direct case analysis.
In summary I would like a type parametrized by n that when n is known
has n distinguishable inhabitants.
Is Fin.t the answer to this question? Or does everything magically
evaporate if I am willing to invoke proof irrelevance? Or is there some
magic encoding I haven't thought of?
Thanks for any help.
-Fred
