coq-club - Re: [Coq-Club] injectivity on existT
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] injectivity on existT
  • Date: Mon, 30 May 2016 15:45:08 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dschepler AT gmail.com; spf=Pass smtp.mailfrom=dschepler AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f47.google.com
  • Ironport-phdr: 9a23:qFFPQhSjOaazR+l+onPbDEuyu9psv+yvbD5Q0YIujvd0So/mwa64YxWN2/xhgRfzUJnB7Loc0qyN4/GmBDBLuMzJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuOP04R3nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs1AbSy09lgdCS1zO6wi/VZPsuAP7sPB80W+UJ5ulY6ozXGGO5qFqRRugsywHOiY9/Xuf3sBrh6JWuBasvTRwxofVZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pKtJXV+c=
On Mon, May 30, 2016 at 2:50 PM, Adam Chlipala
<adamc AT csail.mit.edu>
wrote:
> In general, it requires an axiom. If you [Require Import Eqdep], you get it
> as [inj_pair2].
> On 05/30/2016 05:48 PM, Jonathan Leivent wrote:
>> Is this provable?:
>> Lemma existT_inj : forall T f x a b, @existT T f x a = @existT T f x b ->
>> a = b.
>> I can't prove it with injectivity, or by f_equal with projT2. If it is
>> provable, what's the secret ingredient?
And in a specific case, if you have a decision procedure for equality
to x, then existT_inj holds for that case. (Ex: if T = nat; or if T =
option A, and x = None.)
Daniel Schepler
