coq-club - RE: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>, Coq Club <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • Date: Thu, 2 Jun 2016 18:02:55 +0000
  • Accept-language: de-DE, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga03.intel.com
  • Ironport-phdr: 9a23:TvT0QBeiA8l1U4EB9SaI6fF3lGMj4u6mDksu8pMizoh2WeGdxc+5Zh7h7PlgxGXEQZ/co6odzbGG4ua9CCdZuMbJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuOMk4R3Wr1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S41SGMfjxYAOBDE8xjxXd+luzDit/V00yqyOczmC6gzXSW+4qxrTh7xlSpBOSRvtCn8jdU4p6ZGqlr1rBtmhoXQfYu9Nfxkf6qbc8lMFkRbWcMEHRdGD4ygdYwXS6IkPO1YpoT57RNaqBq1BQChAKX0zTJHmmXxxYU71fgsFUfN2wl2TIFGi2jdsNigbPRaauuy1qSdiGybN/4=
Dear Arnaud,
ahh, that’s what I call haute couture! Many thanks!
Best regards,
Michael
From: arnaud.spiwack AT gmail.com [mailto:arnaud.spiwack AT gmail.com] On Behalf Of Arnaud Spiwack
Sent: Thursday, June 2, 2016 7:44 PM
To: Coq Club <coq-club AT inria.fr>
Cc: Soegtrop, Michael <michael.soegtrop AT intel.com>
Subject: Re: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
When facing this sort of problems, unless you have a single instance and a quick-and-dirty method will suffice. It is often worth it using a combinator which encapsulates the logics (here applying = true to the body of a boolean relation) and on which you can prove properties.
Below a more verbose proof than the above responses, with reusable components:
Require Import Coq.Classes.RelationClasses.
Require Import Coq.Classes.Morphisms.
Require Import Coq.Arith.Arith.
(* Generic lemma, probably has a place in the standard library *)
Instance equivalence_extensional A
  : Proper (@relation_equivalence A ==> Basics.impl) Equivalence.
Proof.
  intros r s eq__rs [r__r s__r t__r]. cbn in eq__rs.
  split.
  all: hnf in *; intros **.
  all: rewrite <- eq__rs in *; eauto.
Qed.
Definition BRel {A} (r:A->A->bool) : A -> A -> Prop :=
  fun x y => r x y = true.
Lemma brel_nat_eqb_eq : relation_equivalence (BRel Nat.eqb) eq.
Proof.
  exact Nat.eqb_eq.
Qed.
Instance nat_eqb_equivalence : Equivalence (BRel Nat.eqb).
Proof.
  rewrite brel_nat_eqb_eq.
  typeclasses eauto.
Qed.
On 2 June 2016 at 19:16, Tej Chajed <tchajed AT mit.edu> wrote:
You can also prove it directly fairly easily, still relying on Nat.eqb_eq. I think this is quite similar in spirit to Emilio's ssreflect proof.
Lemma eqb_equiv : Equivalence (fun m n => Nat.eqb m n = true).
Proof.
  constructor; repeat intro;
    rewrite Nat.eqb_eq in *;
    congruence.
Qed.
On Thu, Jun 2, 2016 at 1:03 PM, Emilio Jesús Gallego Arias <e+coq-club AT x80.org> wrote:
Dear Michael,
"Soegtrop, Michael" <michael.soegtrop AT intel.com> writes:
> Require Export Relations Morphisms Setoid Equalities.
> Require Import Arith.
> Proof.
>   setoid_rewrite Nat.eqb_eq.
I am not sure what you intend to prove, but here's a different proof
your result (using ssreflect's == equality instead of Nat.eqb).
From mathcomp
Require Import ssreflect ssrbool ssrnat eqtype ssrfun seq.
Lemma eqb_equiv : Equivalence (fun m n : nat => m == n).
Proof.
constructor.
- exact: eqxx.
- by move=> x y; rewrite eq_sym.
- by move=> x y z /eqP->.
Qed.
Best,
Emilio
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
