[Coq-Club] help debugging Extraction Implicit failures with Unset Extraction SafeImplicits
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] help debugging Extraction Implicit failures with Unset Extraction SafeImplicits
- Date: Tue, 21 Jun 2016 19:22:57 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f196.google.com
- Ironport-phdr: 9a23:FdtuVhLtsi6B60dtrtmcpTZWNBhigK39O0sv0rFitYgULf7xwZ3uMQTl6Ol3ixeRBMOAuqoC07Od6f6ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14LvjqvopdX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD89pozcNLUL37cqIkVvQYSW1+ayFmrPHs4DLEVEOk4mYWGjEdlQMNCAzY5jn7WI3wu230rLwu9jOdOJjUSrY9RTSr6e9PRR72hSEbf2o792fWicF0ga9zrxeophg5yInRNtLGfMFid7/QKItJDVFKWdxcAmkYWtux
Oops - I just re-read this email and realized I wrote "Extraction Inline" when I meant "Extraction Implicit" :-[
All the same, I still need help....
-- Jonathan
On 06/21/2016 10:54 AM, Jonathan Leivent wrote:
Does anyone have experience debugging Extraction Inline failures with Unset Extraction SafeImplicits? I just tried this for the first time, and am not understanding what went wrong based on the comment placed in the output by Unset Extraction SafeImplicits. The warning is:
Warning:
At least an implicit occurs after extraction : 3rd argument (a) of wfi_lt.
Extraction SafeImplicits is unset, extracting nonetheless,
but this code is potentially unsafe, please review it manually.
The Coq script is attached. The key extracted function is:
let merge_sort d ls =
let rec f _ =
let iH = fun y -> f y in
(fun d0 ls0 _ ->
let (ls1, ls2) = split ls0 in
(match ls2 with
| [] -> ls1
| _ :: _ -> merge_acc d0 (iH (length ls1) (not d0) ls1 __) (iH (length ls2) (not d0) ls2 __) []))
in f __ (* 3rd argument (a) of wfi_lt *) d ls __
end
It looks to me like the first arg of f is understood as not used by extraction. So, what is the comment saying about that arg?
The function wfi_lt (well-founded induction using lt) was defined with:
Definition wfi_lt := well_founded_induction_type Wf_nat.lt_wf.
Extraction Implicit wfi_lt [1 3].
Extraction Inline wfi_lt.
Interestingly, merge_acc also uses wfi_lt, but extraction had no difficulty with it:
let rec merge_acc d ls1 ls2 acc =
match ls1 with
(match ls2 with
| [] -> acc
| b :: ls4 -> merge_acc d [] ls4 (b :: acc))
| a :: ls3 ->
(match ls2 with
| [] -> merge_acc d [] ls3 (a :: acc)
| b :: ls4 -> if le_or_ge_dec d a b then merge_acc d ls1 ls4 (b :: acc) else merge_acc d ls3 ls2 (a :: acc))
This is using 8.5pl1
Thanks,
-- Jonathan
- [Coq-Club] help debugging Extraction Inline with Unset Extraction SafeImplicits, Jonathan Leivent, 06/21/2016
- [Coq-Club] help debugging Extraction Implicit failures with Unset Extraction SafeImplicits, Jonathan Leivent, 06/22/2016
