- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] option to print only certain implicits
- Date: Fri, 24 Jun 2016 14:28:51 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f178.google.com
- Ironport-phdr: 9a23:2MZzOBFh1EEisxqY24XIQ51GYnF86YWxBRYc798ds5kLTJ75pMmwAkXT6L1XgUPTWs2DsrQf2rKQ6/CrADVQqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3pzxj7D5osSDKyxzxxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCmI4HIAUmwQ2j5FAhbI6g2yCpX2tCr5u+5w1QGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Apparently, it works to start a section and do "Local Arguments foo : clear implicit.". Then, upon leaving the section, the implicits are returned.
That's acceptable, since in most cases, I don't need to parse foo when proving with foo...
-- Jonathan
On 06/24/2016 01:22 PM, Jonathan Leivent wrote:
On 06/24/2016 01:08 PM, Ralf Jung wrote:
Hi,
Is there anything like an Arguments command that will allow onlyOne thing you could do is not have that argument implicit, and then
specifically chosen implicits to print? I know I can do Arguments :
clear implicits, but I don't want parsing impacted, and only temporarily
want printing impacted. Set Printing Implicit is a blunt instrument.
The Defensive modifier is also too blunt. I'm hoping maybe there is an
undocumented Argument command that already does this...
The use case is: a particular function where the implicits work very
well parsing-wise, but often become confusing during proving, as when
one sees a conclusion like "foo x = foo x", but reflexivity fails due to
differences in the implicits (even f_equal fails to progress). And
there are many other implicits in other functions around working very
nicely to make the goals easy to read, so using Set Printing Implicit,
Defenisve or not, is not a good idea. In such a case, it would be nice
to do something like "Arguments foo : {no}print implicits" to turn them
on and off, so that foo would always print as @foo.
define a parsing only notation that adds the underscore to trigger
inference. Like
Definition foo (n : nat) := n.
Notation foo' := (foo _) (only parsing).
This means you have to use foo' when writing but will see foo in the
proof state; but other than that, I think the implicits should behave
the way you want.
Kind regards,
Ralf
I was thinking of something like that - actually was going to use another function with implicits (foo') for parsing that just calls the one without (foo) - then unfold foo' during proving would do the trick - I could then even do it on a per hyp/occurrence basis - and then re-fold if desired. Would be even better if there was a variety of transparency that auto-unfolded whenever needed (I think Jason logged a request for something like that), so I wouldn't have to worry about the impact the added layer of def has on the proof.
But, I'm lazy, and this is really just a very minor annoyance. So, I was wondering if the Arguments thing already existed...
-- Jonathan
- [Coq-Club] option to print only certain implicits, Jonathan Leivent, 06/24/2016
- Re: [Coq-Club] option to print only certain implicits, Ralf Jung, 06/24/2016
- Re: [Coq-Club] option to print only certain implicits, Jonathan Leivent, 06/24/2016
