coq-club - Re: [Coq-Club] Question about notations
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Question about notations
  • Date: Thu, 30 Jun 2016 19:55:39 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=voizard AT seas.upenn.edu; spf=Pass smtp.mailfrom=voizard AT seas.upenn.edu; spf=None smtp.helo=postmaster AT fox.seas.upenn.edu
  • Ironport-phdr: 9a23:wbuaThTw0jnrAGQlufTqK56KItpsv+yvbD5Q0YIujvd0So/mwa64ZxGN2/xhgRfzUJnB7Loc0qyN4vimADxLus7JmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6brq9aIO01hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6m4GcbU2Mb2iRPAhrM9h2yCon2sznzrOZVwySTJovrVb0yX3Kv47o9G0ygszsOKzNsqDKfscd3lq8O+B8=
Hi again,
By exploring the output of Print Grammar constr, I managed to make it work with explicit levels:
Notation "{ x , y | P }" := (sig2el (fun x y => P)) (at level 0, x at level 99, y at level 99) : type_scope.
However, if anybody has some good guidelines for seamlessly integrating new notations with old ones, that'd be very helpful.
Antoine
On 2016-06-30 19:22, Antoine Voizard wrote:
Hi all,
I just ran into a problem that I already had a couple of times, and I can't figure out what I'm doing wrong. The general idea is that, when declaring a new notation close to some existing ones, all the sudden Coq's parser won't recognize the old ones, by looking exclusively for the new one.
In this case, I needed an "inlined" version of subsets of pair types (simpler to use than an actual {x : A * B | ...}), so I just adapted the stdlib code:
Inductive sig2el (A:Type) (B:Type) (P : A -> B -> Prop) : Type :=
    exist2el : forall (x : A) (y : B), P x y -> sig2el P.
Notation "{ x , y | P }" := (sig2el(fun x y => P)) : type_scope.
But then, the following gives a syntax error because Coq expects a comma (I tried changing the notation with other characters as well - same result)
Lemma in_dec : forall x L, {x `in` L} + {¬ x `in` L}.
Could you tell me what's the issue?
Thanks,
Antoine
