coq-club - RE: [Coq-Club] ocaml on recent synology
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] ocaml on recent synology
  • Date: Wed, 6 Jul 2016 14:41:26 +0000
  • Accept-language: de-DE, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga09.intel.com
  • Ironport-phdr: 9a23:TkbgfBRe7gF0K5oxk+JeDnbwGdpsv+yvbD5Q0YIujvd0So/mwa64YhGN2/xhgRfzUJnB7Loc0qyN4vimAzJLvsvJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6bopdaMPk1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVG679ZuEzSaFSJDUgKWE8osPx/1GXRgyWo3AYT28+kxxSAgGD4gusDbnrtS6v/NF61SaGJ8ruCfgRWD+i5qpvAle8jSYMNzc09CfMjcF/kLhcuDqgoQByx8jfZ4TDZ6k2Rb/UYd5PHTkJZc1WTSEUWo4=
Dear Michel,
> I need to have ocaml running (at least ocamlrun) on my synology DS115j.
I would cross compile it on cygwin. You can also cross compile it on Linux,
but it is trickier because it is not so common to make a cross gcc where
HOST=TARGET=BUILD. But Cygwin and Linux are different architectures so if you
build a Linux gcc on Cygwin, it is obvious to gcc configure that you want a
cross environment. I think it wouldn't take more than a day to find out how
to configure the cross build in Linux, though.
So you start with creating a "cross" gcc for linux. You use the usual HOST
and TARGET settings in configure. A cross gcc will install to
/usr/<my-special-arch>/sys-root. You can copy shared .so files you need from
the target into the appropriate places under sys-root.
Then you compile ocaml using this gcc.
The technique is similar to cross compiling Coq for MinGW on Linux or Cygwin.
You can have a look at the scripts Enrico is using for building the Coq
Windows SDK. I can also send you my original version, which doesn't have the
installer generation complexities.
See https://github.com/gares/coq/commits/feature/winSDK
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Michel Levy
Sent: Wednesday, July 6, 2016 2:18 PM
To:
Subject: [Coq-Club] ocaml on recent synology
The system running on this server is Linux DiskSynology 3.2.40 : it has no
apt-get, no gcc, so it's impossible to compile the source.
Do you know a solution to install ocaml in such a (hostile) environment ?
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
