- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Shadowing binders abusively renamed?
- Date: Wed, 27 Jul 2016 10:15:31 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f180.google.com
- Ironport-phdr: 9a23:IHDr2RQUnyPa/+2WplrJ2EEzUtpsv+yvbD5Q0YIujvd0So/mwa64ZxeN2/xhgRfzUJnB7Loc0qyN4vimBzFLv8fJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6bsptaNMk1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6t4X0VTmUflFJsDgnb4RfmFsPztS37ted51SSyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
Yannick,
I think this misbehavior of subst is fixed in 8.5pl2.
-- Jonathan
On 07/27/2016 09:50 AM, Yannick wrote:
Dear Coq Club,
I am a bit confused with Coq's behavior towards hypotheses whose name
collude with a definition in its context. Please consider the following
minimal example, also enclosed with the mail:
Ltac inv H := inversion H; try subst; clear H.
Definition bar := False.
Inductive Eq: nat -> nat -> Prop :=
| Eq_def: forall n m, n = m -> Eq n m.
Lemma foo: forall (n:nat) (m:nat) (bar: Eq n m), False.
intros n m bar.
A first observation here: 'intros' would rename bar as bar0, but 'intros
n m bar' will indeed name it bar. I guess it makes sense, we do not want
to shadow unless explicitly required.
What confuses me more is the behavior of subst:
inversion bar. (* Context: bar: Eq n m and a bunch of equalities named
H, H0, H1 *)
subst. (* Context: bar0: Eq m m *)
Here subst actually renamed "abusively" my hypothesis.
Finally, I am at total lost with the following:
Restart.
Fail (intros n m bar; inv bar).
The command has indeed failed with message:
In nested Ltac calls to "inv" and "clear H", last call failed.
Error: Ltac variable H is bound to a value of type var which cannot be
coerced to a variable.
intros n m bar.
inv bar. (** Succeed, by renaming on the way my hypothesis from bar to
bar0 **)
Restart.
intros n m bar.
Fail (inversion bar; subst; clear bar).
No such hypothesis: bar
Given the previous observation on the behaviour of subst, the third case
failing is to be expected. However I do not quite grasp why wrapping it
in a Ltac call allows it to succeed, and even more so why it does not
when chained with a semi-colon.
Naturally, I would agree at any rate that using pre-existing names for
hypotheses is not quite a good policy. However I happened to do it
accidentally and had quite a hard time figuring what was going on. Any
explanation or pointers as to what is really going on in each case, and
confirmation that these behaviours are indeed desired, would be awesome.
Thanks a lot in advance,
Best,
Yannick
- [Coq-Club] Difference between uconstr and open_constr, Robbert Krebbers, 07/27/2016
- Re: [Coq-Club] Difference between uconstr and open_constr, Jonathan Leivent, 07/27/2016
- [Coq-Club] Shadowing binders abusively renamed?, Yannick, 07/27/2016
- Re: [Coq-Club] Shadowing binders abusively renamed?, Jonathan Leivent, 07/27/2016
- Re: [Coq-Club] Shadowing binders abusively renamed?, Yannick, 07/27/2016
- Re: [Coq-Club] Difference between uconstr and open_constr, Pierre-Marie Pédrot, 07/27/2016
