- To: Coq-Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Primitive Projections and Inversion
- Date: Thu, 28 Jul 2016 20:55:43 +0900
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gil.hur AT gmail.com; spf=Pass smtp.mailfrom=gil.hur AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f169.google.com
- Ironport-phdr: 9a23:/aIblRWa7syMZz1b8rRJ9JaK2DnV8LGtZVwlr6E/grcLSJyIuqrYZheOt8tkgFKBZ4jH8fUM07OQ6PG4HzJfqsrZ+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0pcKYP10ArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBI79ZuETSaFSRGAtNHlw78n2vzHCSxGO7z0SSDNFvABPBl3u7Az8UdLSsy+ylvdnkH2VPMmwTa0ucTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hi coq-club,
I am trying to use the new feature "primitive projections".
But, the inversion and dependent destruction tactics do not seem to work for records with primitive projections though it is possible to do inversion manually.
Here is an example.
Require Import Program.
Set Primitive Projections.
Record test := mk {
a : nat;
b : nat
Goal forall a b a' b', mk a b = mk a' b' -> a = a'.
intros.
inversion H. (* does not work *)
dependent destruction H. (* does not work *)
Abort.
intros.
apply (f_equal a) in H.
simpl in H. subst. reflexivity.
Qed.
I wonder whether the inversion tactic will support primitive projections in near future, or there is other ways to do inversion for such records.
Thanks.
Best,
Gil
- [Coq-Club] Primitive Projections and Inversion, Chung-Kil Hur, 07/28/2016
