coq-club - [Coq-Club] trying to understand when destruct rewrites indexes
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] trying to understand when destruct rewrites indexes
  • Date: Sun, 31 Jul 2016 09:35:17 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f180.google.com
  • Ironport-phdr: 9a23:JtuPtxFqM0Pwe+rvSWtj251GYnF86YWxBRYc798ds5kLTJ75ocqwAkXT6L1XgUPTWs2DsrQf2rKQ7PurBzFIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14LojKvsptX6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuwwZgf8q9tZBXKPmZOx4COUAVHV1e1wysebsrFHoSRaFri8XVXxTmR5VCSDE6gv7V9H/qH2pmPB63Xy4Osv/UbA9X3yG4qZ1RRn0wHMFMDg482zTh8FYg6dSoRbnrBt6ld2HKLqJPeZzK/uONegRQnBMC4MID3RM
When destructing an instance of a type with indexes, destruct will often rewrite occurrences of terms that are index args elsewhere in the goal. But which occurrences and when? The rules appear to be ad-hoc. For instance:
Inductive Foo (n : nat) : nat -> Type := foo1 : Foo n 1.
Variable P : forall A (a:A), Prop.
Variable G : nat -> Type.
Goal forall n (f : Foo 42 (S n)), G (S n) -> P _ f.
intros n f g.
destruct f. (*g becomes g : G 1*)
Abort.
Goal forall n (f : Foo (S n) (S n)), G (S n) -> P _ f.
intros n f g.
destruct f. (*g stays g : G (S n)*)
Abort.
Why is the treatment of g's type by the two destructs above different? Is it just because the term (S n) appears as a parameter and an index to Foo in the second goal, but only as an index in the first? But, what justifies this behavior? Also, what justifies not changing the (S n) parameter of f's type in the second goal?
A possibly related question - if one replaces destruct in the above two goals with dependent simple inversion, this works in the first goal but fails in the second with a cryptic error message:
Error: In environment
n : nat
f : Foo (S n) (S n)
X : G (S n)
n0 : nat
Unable to unify "Foo n0 n0" with "Foo ?M190 n0".
Why can't it do that unification in that environment?
This is all using 8.5pl2.
-- Jonathan
  • [Coq-Club] trying to understand when destruct rewrites indexes, Jonathan Leivent, 07/31/2016
