- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coq_makefile and the -q option
- Date: Tue, 2 Aug 2016 13:12:48 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f171.google.com
- Ironport-phdr: 9a23:tFt+1RTmZjYpUCZKRCZXLW+wR9psv+yvbD5Q0YIujvd0So/mwa64ZxeN2/xhgRfzUJnB7Loc0qyN4vimBjxLvszJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mj6btq9aMOU1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6t4X0VTmUflFJsDgnb4RfmFsPztS37ted51SSyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
On 08/02/2016 12:26 PM, Jason Gross wrote:
Oh, I see, you want to use it to locate projects. I thought you were using
it for settings. (Just imagine how hard it would be to track down failures
when someone decided that [Set Primitive Projections. Set Universe
Polymorphism. Set Asymmetric Patterns. Set Keyed Unification.] was a good
resource file to have.) I think COQPATH is the standard way of doing this,
however annoying it may be. (I think it's actually better than resource
files, given that I use my resource files for things like "disable the
display of dependent evars in emacs" and other settings.)
Yes - I was only intending to use it to locate projects, by having Add LoadPath lines in the resource file, per section 14.3.1 of the refman. I have instead used COQPATH, but am not happy with that:
Using COQPATH to tie together separate projects means that the logical names have to match the physical names. So, this can't be the final answer, can it? Isn't segregating logical from physical names supposed to be the new best-practice? And, isn't it more important to segregate logical names from physical names between distinct projects than it is to do so within a single project?
Also, using environment variables for settings that are to be shared by many tools is often problematic, due to the way different tools pick up environment variable settings from different places. For example, in order to get PG to respect the same COQPATH env var I use for shells, I had to install exec-path-from-shell, and put (exec-path-from-shell-copy-env "COQPATH") in my coq-mode-hook. Just because I launch Emacs from a toolbar instead of from a shell. I could have instead put a bash shell script wrapper around Emacs and launch that script instead from the toolbar - but the point is that something has to be done specially to pick up env vars in many cases.
But, why put in refman section 14.3.1, and have coq_makefile hardwire the -q option? And at the same time have the Coq tools always ignore -init-file if -q is anywhere on the same command line?
If you want to enforce that resource files for Coq only have useful and benign settings in them - like Add LoadPath, but not Set Asymmetric Patterns - then enforce that when loading the resource file. And put it in the refman, without contradicting it in the tools!
Sorry, should have warned you to put on your flame-proof goggles before saying that....
-- Jonathan
On Tue, Aug 2, 2016 at 6:46 AM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On 08/02/2016 03:53 AM, Jason Gross wrote:
Makefiles should be portable. A Makefile that only works on your machineJason,
is not very useful. Consider instead having an extra file, maybe
Settings.v, which you build with a separate Makefile, and pass -require
MyProject.Settings along to your build process.
How does the mechanism you propose help matters? The Settings.v file
then becomes the point of conflict. If each project must have its own
Settings.v file that tells it where all other projects are on that
machine, then each time that project is transferred to a different
machine, the project's local Settings.v must change. If, instead, one
uses something like a symbolic link to a global Settings.v file for that
machine, then that effectively re-creates the resource file mechanism.
But, supposing you are correct - why isn't this mechanism documented
instead of resource files and COQPATH? RTFM-GF'd?
-- Jonathan
Why do Makefiles generated via coq_makefile pass -q to coqc?
If a user decides they want to use a resource file (one that for example
Adds to the LoadPath), how do they configure coq_makefile to use it?
-- Jonathan
- [Coq-Club] coq_makefile and the -q option, Jonathan Leivent, 08/01/2016
- Re: [Coq-Club] coq_makefile and the -q option, Jason Gross, 08/02/2016
- Re: [Coq-Club] coq_makefile and the -q option, Jonathan Leivent, 08/02/2016
