[Coq-Club] Two Industrial PhD Student Positions in Formal Logic at the University of Barcelona
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: JOOST JOOSTEN <jjoosten AT ub.edu>
- Subject: [Coq-Club] Two Industrial PhD Student Positions in Formal Logic at the University of Barcelona
- Date: Fri, 05 Aug 2016 06:37:37 +0000
- Accept-language: en-GB, es-ES, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jjoosten AT ub.edu; spf=None smtp.mailfrom=jjoosten AT ub.edu; spf=None smtp.helo=postmaster AT caout03.ird.ub.es
- Ironport-phdr: 9a23:jScCPhGTlq2WmX0PadbCA51GYnF86YWxBRYc798ds5kLTJ75osywAkXT6L1XgUPTWs2DsrQf2rKQ4/urADRaqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3pzxh7v5osWJKyxzxxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JsKWqLjOq88ULZwDTI8Mmlz6teh/U3IShLK7X8BWE0XlABJCk7L9kepcI32t37Ykc1G5GG4GurNcZ0SEWCg7aBsUwPljg8aPXg0/HyB2Z84t75SvB/0/083+IXTeozAbPc=
The University of Barcelona offers two PhD positions in collaboration with the Catalan industrial sector. As such, the industrial component of the PhD revolves around the development and verification of legal software in Coq. This work will be complemented
with the formalization of parts of logic/mathematics. Since the group where this project will be embedded works on ordinal analysis via modal logic and reflection principles, we expect collaboration with the main group to arise, but we are open to alternative
proposals.
We offer two three-year positions in the PhD program in Mathematics and Computer Science which is located in the very center of Barcelona. Apart from the usual PhD trajectory, the candidates will participate in cutting-edge developments in formalization
in an industrial setting. The travel allowances can vary to over 2200 € per year and the gross salary varies between 18 K and 22 K per year, depending on how much financial support this project will receive from the Catalan authorities. Incorporation should
take place between November 2016 and February 2017.
We are looking for candidates with a background in theoretical computer science and/or mathematical logic. It is a strict requirement to have finished a relevant Master with an average score of at least 6.5 (out of 10) over all courses taken in both the master
and undergraduate studies. Apart from the required knowledge of proof assistants like Coq, and Ocaml, other IT skills are recommended, especially knowledge/experience with other functional programming languages. Previous commercial work experience is a plus
and working proficiency in English is a must.
Interested candidates should file their pre-application through the official application portal at
http://doctoratsindustrials.gencat.cat/en.
In order to distinguish the two PhD student positions, we tentatively tagged them `The Syntax Road' and `The Semantics Road', respectively. It is true that indeed one part of the formalization of our mathematics project involves modal calculi whereas
another part will emphasize on relational (Kripke) semantics, but choosing at this stage for one of the Syntax or Semantics road does not imply any irreversible decision.
Direct links to the pre-application are
and
Upon filing this pre-application, you should send additional information to
jjoosten AT ub.edu, no later than September 10th, 2016. The additional information should at least contain:
(+) CV;
(+) motivation letter;
(+) transcript of obtained academic results in the relevant master and undergraduate;
(+) e-mail addresses of three references to whom we might refer if needed.
Further information about the positions can be obtained by writing an e-mail to Joost J. Joosten at
jjoosten AT ub.edu.
Aquest correu electrònic i els annexos poden contenir informació confidencial o protegida legalment i està adreçat exclusivament a la persona o entitat destinatària. Si no sou el destinatari final o la persona encarregada de rebre’l, no esteu autoritzat a llegir-lo, retenir-lo, modificar-lo, distribuir-lo, copiar-lo ni a revelar-ne el contingut. Si heu rebut aquest correu electrònic per error, us preguem que n’informeu al remitent i que elimineu del sistema el missatge i el material annex que pugui contenir. Gràcies per la vostra col·laboració.
Este correo electrónico y sus anexos pueden contener información confidencial o legalmente protegida y está exclusivamente dirigido a la persona o entidad destinataria. Si usted no es el destinatario final o la persona encargada de recibirlo, no está autorizado a leerlo, retenerlo, modificarlo, distribuirlo, copiarlo ni a revelar su contenido. Si ha recibido este mensaje electrónico por error, le rogamos que informe al remitente y elimine del sistema el mensaje y el material anexo que pueda contener. Gracias por su colaboración.
This email message and any documents attached to it may contain confidential or legally protected material and are intended solely for the use of the individual or organization to whom they are addressed. We remind you that if you are not the intended recipient of this email message or the person responsible for processing it, then you are not authorized to read, save, modify, send, copy or disclose any of its contents. If you have received this email message by mistake, we kindly ask you to inform the sender of this and to eliminate both the message and any attachments it carries from your account. Thank you for your collaboration.
- [Coq-Club] Two Industrial PhD Student Positions in Formal Logic at the University of Barcelona, JOOST JOOSTEN, 08/05/2016
