- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about multiple imports of the same modules
- Date: Wed, 10 Aug 2016 03:45:24 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f179.google.com
- Ironport-phdr: 9a23:PR49ABf2kdiGq70f7WboOdGmlGMj4u6mDksu8pMizoh2WeGdxc6/YB7h7PlgxGXEQZ/co6odzbGH6ua4Aydesd7B6ClEK80UEUddyI0/pE8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrDbg8n/7e2u4ZqbO1wO32vkJ+soZ0vm5UWJ749N0NMkcv5wgjLy4VJwM9xMwm1pIV/B1z3d3eyXuKBZziJLpvg6/NRBW6ipN44xTLhfESh0ezttvJ6j5lH/Sl6E4WJZWWELmDJJBRLE5Vf0RMTfqCz/48h0wy6cdeLsSqsvEWCg5rxsThDyjzwcZhY29WjWjop7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
The problem has nothing to do with files or imports and everything to do with module functors. Functors are generative: Every time you apply a module functor, you get a fresh copy of every definition. In particular, the inductive types and axioms you get by applying a functor twice do not unify. The solution is to move inductive type definitions (and axioms, if need be) outside of your functors.
On Tue, Aug 9, 2016, 7:03 PM John Wiegley <johnw AT newartisans.com> wrote:
Hello,
I have a project that I'd like to modularize more using module functors. I
end up with a dependency tree similar to the following:
A: defines "foo"
B: imports A to use "foo"
C: imports A to use "foo"
D: imports both B and C
What happens is that I run into a situation in D where [B.foo] and [C.foo] are
not considered the same type. I have attached an example below. Is there any
way to tell Coq that the definitions imported by B and C from A are to be
regarded as the same?
Thanks,
John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- [Coq-Club] Question about multiple imports of the same modules, John Wiegley, 08/10/2016
- Re: [Coq-Club] Question about multiple imports of the same modules, Jason Gross, 08/10/2016
