- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq Tutorial
- Date: Thu, 11 Aug 2016 20:55:18 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jecs AT imperial.ac.uk; spf=Pass smtp.mailfrom=jecs AT imperial.ac.uk; spf=None smtp.helo=postmaster AT smtp2.cc.ic.ac.uk
- Ironport-phdr: 9a23:cgVyPRMIbsN3uubix6wl6mtUPXoX/o7sNwtQ0KIMzox0KPn/rarrMEGX3/hxlliBBdydsKMdzbKJ+Pm8ASRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmLiKuoudF329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrJ6jiR6WRgyWo3AYT28+kxxSAgGD4gupcI32t37Yv+9ww2GhOMzqTfhgWzmp9I9qTQflkiYOM3gw+yfKiZoj3+pgvBu9qkknkMbva4aPOa8mcw==
Gergely, hi,
I'm no expert on Coq but you might want to try this:
http://adam.chlipala.net/cpdt/
There is a PDF draft available, too, if you prefer that format.
Kind regards,
James
On 11/08/16 11:03, Gergely Buday wrote:
Hi,
I see
https://coq.inria.fr/tutorial/
as an interactive tutorial
and
http://flint.cs.yale.edu/cs430/coq/pdf/Tutorial.pdf
as a printable one. Is the latter up-to-date? If not, is there one to download and print?
- Gergely
- [Coq-Club] Coq Tutorial, Gergely Buday, 08/11/2016
- Re: [Coq-Club] Coq Tutorial, James Smith, 08/11/2016
- Re: [Coq-Club] Coq Tutorial, mukesh tiwari, 08/12/2016
