coq-club - [Coq-Club] more naive questions about rewriting
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] more naive questions about rewriting
  • Date: Tue, 16 Aug 2016 14:32:06 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=Pass smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-wm0-f42.google.com
  • Ironport-phdr: 9a23:P6mLnxyEZ9fwusvXCy+O+j09IxM/srCxBDY+r6Qd0e8XIJqq85mqBkHD//Il1AaPBtSCrasbwLOL7+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVwXz2PgPfsydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8LPuyf7s6JP0S2bI8S+Ga4mUDCj8a5DQxr1zioLKmhqoynslsVsgfcD81qarBtlztuMbQ==
I have more questions about 'rewrite' tactics. Here is an artificial example, which illustrates what I am trying to do. I need to rewrite a part of an _expression_ under Leibnitz equality.
Require Import Coq.Program.Basics.
Require Import Coq.Program.Combinators.
Require Import Coq.Setoids.Setoid.
Unset Printing Notations.
Lemma Foo
      {A:Type}
      (f0 f1 f2 f3 f4: A->A)
    compose f1 (compose f2 (compose f3 f4))  =
    compose f1 (compose (compose f2 f3) f4).
Proof.
  intros.
  (* I know, `using reflexivity` works here, but I want to prove by rewriting *)
  (* The following does not work. Error: Tactic failure: Nothing to rewrite. *)
  try rewrite <- compose_assoc at 2.
  (* However, the following works OK. *)
  replace (compose f2 (compose f3 f4)) with (compose (compose f2 f3) f4)
    by apply compose_assoc.
  reflexivity.
Qed.
The equation I am working with are actually much more elaborate than one above, and rewriting parts of it using 'replace' makes my proofs difficult to read.I have to copy-paste ~100 line expressions into 'replace' arguments.
I would love to be able to rewriting positionally, using something like 'rewrite lemma at 2.' If standard rewrite tactics, does not allows this, perhaps it could be automated somehow?
CMU ECE PhD candidate
Mobile: +1(510)220-1060
