- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [Function] with measure?
- Date: Tue, 23 Aug 2016 19:01:25 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f172.google.com
- Ironport-phdr: 9a23:kglxkBLhWBf2VkNOYNmcpTZWNBhigK39O0sv0rFitYgULfrxwZ3uMQTl6Ol3ixeRBMOAuqsC0Led6vCoGTRZp83Q6DZaKN0EfiRGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkJLL+j4UrTfk96wn7jrvcaCOkMT2XHkMfsydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vh7aCACL+3FUBm4Ri19DBxXPxBD8RJb49CXg4LlTwi6faOT8TbEvWTmhp45tQRnkwHMOPT4462HaiYp5iqtdrFSgpgBw64HRaYCRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5XAg==
"Grab Existential Variables." may let you make progress on those invisible subgoals.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Aug 23, 2016 6:37 PM, "Randy Pollack" <rpollack0 AT gmail.com> wrote:
I define a function using a measure, e.g.
Function foo (xs:list nat) : nat :=
match xs with ... end.
The function is accepted and an obligation goal is generated.
I solve the obligation and the Coq response is
No more subgoals.
(dependent evars:)
Neither Qed nor Defined is accepted at this point, and the function
foo is "not found in the current environment."
I did not find in the RefMan how to finish this definition.
Thanks for any help.
--Randy
- [Coq-Club] [Function] with measure?, Randy Pollack, 08/24/2016
- Re: [Coq-Club] [Function] with measure?, Abhishek Anand, 08/24/2016
- Re: [Coq-Club] [Function] with measure?, Pierre Courtieu, 08/24/2016
