- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] help with automating derived UIP_refl proofs
- Date: Wed, 31 Aug 2016 18:14:15 +0200
- Organization: LORIA
As a complement to the library of Adam about UIP inheritance properties,
it also works for inductively defined types such as lists, trees ...
Require Import List.
Section UIP_list.
Variable X : Type.
Implicit Type l : list X.
Hypothesis eqX_uniq : forall (x : X) (e : x = x), e = eq_refl.
Let list_cons_eq x y l m (e1 : x = y) (e2 : l = m) : x::l = y::m :=
match e1, e2 with
eq_refl, eq_refl => eq_refl
end.
(* eq_inv_type l m H expresses that the proof H : l = m is
build exclusively from either eq_refl nil or list_cons_eq *)
Let eq_inv_prop n : forall m, n = m -> Prop :=
match n with
| nil => fun m =>
match m with
| nil => fun H => H = eq_refl
| _ => fun _ => False
end
| a::l => fun m =>
match m with
| nil => fun _ => False
| b::m => fun H => exists (H1 : a = b)
(H2 : l = m), H = list_cons_eq H1 H2
end
end.
Let eq_inv l m H : @eq_inv_prop l m H.
Proof.
subst m.
destruct l; simpl.
* trivial.
* exists (eq_refl _), (eq_refl _); reflexivity.
Qed.
Theorem UIP_list l (H : l = l) : H = eq_refl.
Proof.
induction l as [ | x l IHl ].
* exact (eq_inv H).
* destruct (eq_inv H) as (H3 & H4 & HH).
rewrite HH, (IHl H4), (eqX_uniq H3); reflexivity.
Qed.
End UIP_list.
On 08/28/2016 09:44 PM, Adam Chlipala wrote:
> I think proving this kind of goal is simpler via first building a
> library of theorems for porting UIP between types, like so:
> Set Implicit Arguments.
> (** * Step 1: UIP ports across type isomorphism. *)
> Section UIP_iso.
> Variables A B : Type.
> Variable AtoB : A -> B.
> Variable BtoA : B -> A.
> Hypothesis AtoB_BtoA : forall a, AtoB (BtoA a) = a.
> Hypothesis A_UIP_refl : forall (a : A) (e : a = a), e = eq_refl.
> Lemma f_equal_cancel : forall (x y : B) (e : x = y),
> e = match AtoB_BtoA x in _ = X return X = _ with
> | eq_refl =>
> match AtoB_BtoA y in _ = Y return _ = Y with
> | eq_refl => f_equal AtoB (f_equal BtoA e)
> end
> end.
> Proof.
> intros.
> subst.
> simpl.
> generalize (AtoB_BtoA y).
> destruct e.
> reflexivity.
> Qed.
> Theorem UIP_iso : forall (b : B) (e : b = b), e = eq_refl.
> Proof.
> intros.
> rewrite (f_equal_cancel e).
> rewrite (A_UIP_refl (f_equal BtoA e)).
> simpl.
> generalize (AtoB_BtoA b).
> generalize (AtoB (BtoA b)).
> intros.
> subst.
> reflexivity.
> Qed.
> End UIP_iso.
> Section example.
> Variable A : Type.
> Hypothesis A_UIP_refl : forall (a : A)(e : a=a), e=eq_refl.
> Record Foo := foo { foo_a : A }.
> Lemma Foo_UIP_refl : forall (f : Foo)(e: f=f), e=eq_refl.
> Proof.
> apply UIP_iso with (AtoB := foo) (BtoA := foo_a); auto.
> destruct a; auto.
> Qed.
> End example.
> (** * Step 2: UIP is preserved by pairing. *)
> Section UIP_pair.
> Hypothesis B_UIP_refl : forall (b : B) (e : b = b), e = eq_refl.
> Lemma pair_eta : forall p : A * B,
> (fst p, snd p) = p.
> Proof.
> destruct p; reflexivity.
> Defined.
> Lemma pair_cong : forall (a1 a2 : A) (b1 b2 : B),
> a1 = a2
> -> b1 = b2
> -> (a1, b1) = (a2, b2).
> Proof.
> intros.
> subst.
> reflexivity.
> Defined.
> Lemma f_equal_cancel' : forall (x y : A * B) (e : x = y),
> e = match pair_eta x in _ = X return X = _ with
> | eq_refl =>
> match pair_eta y in _ = Y return _ = Y with
> | eq_refl => pair_cong (f_equal (@fst _ _) e) (f_equal (@snd
> _ _) e)
> end
> end.
> Proof.
> intros.
> subst.
> generalize (pair_eta y).
> destruct e.
> reflexivity.
> Qed.
> Theorem UIP_pair : forall (a_b : A * B) (e : a_b = a_b), e = eq_refl.
> Proof.
> intros.
> destruct a_b.
> rewrite (f_equal_cancel' e).
> rewrite (A_UIP_refl (f_equal (@fst _ _) e)).
> rewrite (B_UIP_refl (f_equal (@snd _ _) e)).
> reflexivity.
> Qed.
> End UIP_pair.
> Section example2.
> Hypothesis B_UIP_refl : forall (b : B)(e : b=b), e=eq_refl.
> Record Bar := bar { bar_a : A; bar_b : B }.
> Lemma Bar_UIP_refl : forall (f : Bar)(e: f=f), e=eq_refl.
> Proof.
> apply UIP_iso with (AtoB := fun x => bar (fst x) (snd x))
> (BtoA := fun x => (bar_a x, bar_b x)).
> destruct a; auto.
> apply UIP_pair; auto.
> Qed.
> End example2.
- [Coq-Club] help with automating derived UIP_refl proofs, Jonathan Leivent, 08/28/2016
- Re: [Coq-Club] help with automating derived UIP_refl proofs, Jonathan Leivent, 08/28/2016
- Re: [Coq-Club] help with automating derived UIP_refl proofs, Adam Chlipala, 08/28/2016
- Re: [Coq-Club] help with automating derived UIP_refl proofs, Jonathan Leivent, 08/29/2016
- Re: [Coq-Club] help with automating derived UIP_refl proofs, Dominique Larchey-Wendling, 08/31/2016
- Re: [Coq-Club] help with automating derived UIP_refl proofs, Jonathan Leivent, 08/31/2016
