- From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re:[Coq-Club]
- Date: Mon, 5 Sep 2016 20:13:46 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:Oy1edhyoB9WVX1DXCy+O+j09IxM/srCxBDY+r6Qd0ewSIJqq85mqBkHD//Il1AaPBtSCra8UwLOP4+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVgYz2PkMfsydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8Leuybmv+w19yieN8DsUfhgVj2v865tDhDpjC0KLSIR/WfMz8hhi6Qdrgj39E83+JLdfIzAbKk2RajaZ95PHWc=
If I'm reading it right that lemma says for any point x and any n, there is a path of length n between x and root. This seems unlikely to be true. You might want something like forall x, v x -> {el : A_list & Connection x root el (distance x)} for path_to_root, which says that for any point x there is a path of length (distance x) between x and root. Then you can modify it to forall n, forall x, v x -> distance x = n -> {el : A_list & Connection x root el n } and then you can do induction on n. Additional remarks: I'm not familiar with this library but it seems like it would be cleaner to have (g : Graph v a) and (propRoot : v root) as section variables. In the definition of Connection, why is the inductive argument to
step [Connection y z el (S n)] and not [Connection y z el n]?
Doesn't this make it impossible to define any Connection of
nonzero length? The parent_exists axiom is strange, I would have expected
something like forall c, v c -> v (parent c). Gaëtan Gilbert On 05/09/2016 17:50, Samira Akili
wrote:
Hi
everyone,
we are
using the graph library GraphBasics and want to show that if
some self-defined properties are true for all vertices of a
graph the resulting graph is a tree.
First, we want to show the connectivity by proving that there is a path between any vertex and the root by induction over the pathlength, which is descibed by the following lemma. Lemma path_to_root_inductive: forall (g : Graph v a)(x :Component)(prop1: v x) (prop2: v root)(n:nat), {el : A_list & Connection x root el n}. We use these axioms and definitions: Definition Component := Vertex. Variable v: U_Set Component. Variable a: A_set. Variable root: Component. Definition distance: Component -> nat. Axiom distance_root : distance root = 0. Axiom distance_prop : forall (c:Component)(a:A_set)(v:V_set)(g: Graph v a) (prop :v c), c <>root -> distance c = distance (parent c) + 1. Definition parent : Component -> Component. Axiom parent_root := parent root = root. Axiom parent_exists : forall (c :Component)(g: Graph v a)(prop: v c), exists (k: Component), v k -> parent c = k. (*Connection is an undirected path consisting of edges that are induced by the parent relation, each path has its that has a length*) Inductive Connection: Component -> Component -> A_list -> nat -> Set := | self : forall x:Vertex, v x -> Connection x x A_nil 0 | step : forall (x y z : Vertex)(el : A_list)(n:nat), Connection y z el (S n) -> v x -> parent x = y -> a (A_ends x (parent x)) -> a (A_ends (parent x) x) -> ~ In (A_ends x (parent x)) el -> ~ In (A_ends (parent x) x) el -> Connection x z ((A_ends (parent x) x ) :: el) (S(S n)). We try to prove the lemma path_to_root_inductive by induction over n. Our induction hypothesis looks like this: IHn : {el : A_list & Connection x root el n} and our goal like this {el : A_list & Connection x root el (S n)} What we need instead is an induction hypothesis that looks like this: IHn : {el : A_list & Connection y root el n} with (y = parent x) How can we change the induction scheme to fit our purpose? |
- [Coq-Club], Samira Akili, 09/05/2016
- Re:[Coq-Club], Gaetan Gilbert, 09/05/2016
- Re:[Coq-Club], Samira Akili, 09/06/2016
- Re:[Coq-Club], Gaetan Gilbert, 09/06/2016
