coq-club - Re: [Coq-Club] PG indentation
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] PG indentation
  • Date: Mon, 12 Sep 2016 16:07:13 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:pdvkPxQajvTqCp/IdHV/LfwNyNpsv+yvbD5Q0YIujvd0So/mwa67bBWN2/xhgRfzUJnB7Loc0qyN4vmmBzxLuMrd+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYZBwNjz6ga5tzKg+3pEPfrJo4m4xnf401Sx7EpGd/Q+VKgCZDIVuOkxv4rpO7+JNm/iJM/eog6+ZPVKz7e+IzSrkOX2duCHw8+MC+7UqLdgCI/HZJCmg=
On 2016-09-12 15:14, Beta Ziliani wrote:
> Dear Clément,
Dear Beta,
Thanks for the example.
> Coq Indent Box Style: off (nil)
> Coq Script Indent: off (nil)
Sorry; I meant to ask how you set the settings: through the Emacs "customize"
interface, or using a plain setq in your .emacs?
The first setting is unrelated to the indentation of the example below (see
its docs with C-h v); it seems that the second one is broken, however; a bug
report would be useful. It would also help if you pointed out which parts
are different from old releases of PG.
> Example indent_test : True.
The fact that the code in question contains multiple keywords (is, and)
doesn't help, but I can answer some of the questions :)
> Proof.
> let why_this_is_indentend :=
I think you're looking for coq-indent-proofstart:
(setq coq-indent-proofstart 0)
> and why this is here in
I don't think we have a setting for continuation lines of ‘let’s.
> x <- some MetaCoq code;
> y <- ouch this shouldnt be indented;
> ret why_isnt_this_indented_BTW.
Would (setq coq-indent-semicolon-tactical 0) help?
Number of spaces used to indent after the first tactical semi colon of a
serie.
If set to 0, indetation is as follows:
tac1;
tac2;
tac3;
tac4.
if set to 2 (default):
tac1;
tac2;
tac3;
tac4.
Otherwise, adding a parens fixes it: (x <- …). In general, I don't think you
can expect PG to indent your notations properly, at least not without support
from Coq.
> I prefer to set the tab as two spaces, and mange it myself. But Proof
> General is inserting its own indentation
Correct. What do you usually bind TAB to? Rebinding it Coq mode should work
too.
> (and sometimes in a weird way, see e.g. the two lines ending with ;).
This is expected; see the documentation that I pasted above :)
> And what is really pissing me off is that it is changing the
> indentation I wrote. For instance, if I decide to move the y <- ouch
> ... code so it is aligned with the previous line, after hitting enter
> PG will move it back to where it is in the code above. Maybe there are
> some other options I’m missing?
Are you using electric-indent-mode maybe? That would explain the behavior of
RET. (PG doesn't do anything like this)
Cheers,
Clément.
> On Mon, Sep 12, 2016 at 3:58 PM, Clément Pit--Claudel
> wrote:
>> Hi Beta,
>> How do you set these settings? Can you share a snippet and show the
>> expected indentation?
>> Cheers,
>> Clément.
>> On 2016-09-12 14:47, Beta Ziliani wrote:
>>> Hi list,
>>> I updated PG and now it is indenting my code in a way I don't want it
>>> to. I'm aware of the options Coq Script Indent and Coq Indent Box
>>> Style, however they seem to have no effect whatsoever. Any clues?
>>> Thanks,
>>> Beta
Attachment: signature.asc
Description: OpenPGP digital signature
