- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Tactic to collect hypothesis of given type in a list
- Date: Wed, 14 Sep 2016 15:50:14 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=bziliani AT famaf.unc.edu.ar; spf=None smtp.mailfrom=bziliani AT famaf.unc.edu.ar; spf=None smtp.helo=postmaster AT famaf.unc.edu.ar
- Ironport-phdr: 9a23:98xxrxGdK4vQrN3PcIJLXZ1GYnF86YWxBRYc798ds5kLTJ75rs6wAkXT6L1XgUPTWs2DsrQf2rOQ7PurBzBIoc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XziOvgscF329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrOWijxTITBOO630ASS1W10MQW0mWpC39C7z2q2PRsvd3kH2ROtSzRrQpUxyj6b1qQVnmknFUGSQ+9TT9h9B5xJBapBOooR03l4TGYYWUPfx/Vq3UeNoUA3dHVYBcWzEHC5nqPNhHNPYIIesN99q1nFAJtxbrQFD0XO4=
If you don’t mind using plugins, you might consider MetaCoq[1], where
such type of programming is quite natural.
Here is a function that takes a type and filters the hypotheses of
that type. I made the function a tactic that only prints the filtered
list since you asked for a tactic and a function.
Definition filter_hyps (T: Type) : tactic :=
l <- hypotheses;
l <- MCListUtils.mfilter
(fun h=>
mmatch h with
| [? (x: T) d] ahyp x d => ret true
| _ => ret false
end) l;
print_term l;;
exact I.
To run the example using the MProof environment:
Example filter_ex (a: bool) (x y z : nat) (c: x > y) : True.
MProof.
filter_hyps nat.
Qed.
Or to do it inside a normal Coq Proof:
Notation "'evalT' t" := (eval (run_tac t)) (at level 0).
Example filter_ex_no_mproof (a: bool) (x y z : nat) (c: x > y) : True.
Proof.
refine (evalT (filter_hyps nat)).
Qed.
Best,
Beta
[1] https://github.com/MetaCoq/MetaCoq
On Wed, Sep 14, 2016 at 1:43 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
> On 09/14/2016 12:34 PM, Soegtrop, Michael wrote:
>> Dear Coq Users,
>> I need a tactic to collect all hypothesis of a given type in a list. The
>> un-elegant and restricted version below somehow works, but I am looking for
>> something which would work for any number of hypothesis.
>> I wanted to use a recursive function and clear the hypothesis in each step
>> (this would be ok), but as far as I know an Ltac function can either return
>> a value or manipulate the goal but not both.
>> Does someone have something similar?
> There is Gregory Malecha's plugin, which can be used to iterate over
> hypotheses: https://github.com/gmalecha/coq-ltac-iter
> Without plugins, I have a set of tactics that can get a list of the current
> hypotheses and iterate over them, including filtering by type. But, they're
> somewhat kludgey - depending on tactic-in-term behaviors.
> Also, there is a way that an Ltac tactic can both return a value and
> manipulate the goal - using a dummy let that is assigned a trivial match
> where the branch does the manipulation:
> let dummy := match goal with _ => manipulating_tac end in
> let result := ... in result.
> -- Jonathan
>> Alternatively an example for constructing a list in a hypothesis by
>> keeping the tail an evar would be useful. I tried a few things but always
>> get typing errors, when I instantiate an existing evar with something like
>> head :: newevar.
>> Thanks & best regards,
>> Michael
>> Open Scope list_scope.
>> Inductive PropWrap : Prop :=
>> | SomeProp {P : Prop} (p : P)
>> | NoneProp
>> Ltac CollectPropWrap :=
>> lazymatch goal with
>> | H1 := ?h1 : PropWrap, H2 := ?h2 : PropWrap, H3 := ?h3 : PropWrap |- _
>> => constr:(h1::h2::h3::nil)
>> | H1 := ?h1 : PropWrap, H2 := ?h2 : PropWrap |- _
>> => constr:(h1::h2::nil)
>> | H1 := ?h1 : PropWrap |- _
>> => constr:(h1::nil)
>> end.
>> Intel Deutschland GmbH
>> Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
>> Tel: +49 89 99 8853-0, www.intel.de
>> Managing Directors: Christin Eisenschmid, Christian Lamprechter
>> Chairperson of the Supervisory Board: Nicole Lau
>> Registered Office: Munich
>> Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] Tactic to collect hypothesis of given type in a list, Soegtrop, Michael, 09/14/2016
- Re: [Coq-Club] Tactic to collect hypothesis of given type in a list, Jonathan Leivent, 09/14/2016
- Re: [Coq-Club] Tactic to collect hypothesis of given type in a list, Beta Ziliani, 09/14/2016
- RE: [Coq-Club] Tactic to collect hypothesis of given type in a list, Soegtrop, Michael, 09/15/2016
