- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] prod is still polymorphic over sort Type/Prop ?
- Date: Mon, 19 Sep 2016 13:28:17 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb0-f180.google.com
- Ironport-phdr: 9a23:ub4QABL8h1VOTlHg99mcpTZWNBhigK39O0sv0rFitYgULfrxwZ3uMQTl6Ol3ixeRBMOAuqsC27ad4vyoGTRZp83Q6DZaKN0EfiRGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkJLL+j4UrTfk96wn7jrvcaCOkMY2HHsPfsydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vh7aCACL+3FUBm4Ri19DBxXPxBD8RJb49CXg4LlTwi6faOT8TbEvWTmhp45tQRnkwHMOPT4462HaiYp5iqtdrFSgpgBw64HRaYCRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5XAg==
(* checked in Coq versions 8.5pl1 and 8.5pl2 *)
Variable A:Prop.
Variable B:Prop.
Variable AT:Type.
Variable BT:Type.
Check (prod AT BT).
(* Type *)
Fail Check ((prod AT BT):Prop).
Check (A:Type).
Check ((prod A B)).
(* Prop
How is this justified?
I expected Type.
Check prod.
prod
: Type -> Type -> Type
Fail Check (AT:Prop).
-- Abhishek
http://www.cs.cornell.edu/~aa755/- [Coq-Club] prod is still polymorphic over sort Type/Prop ?, Abhishek Anand, 09/19/2016
- Re: [Coq-Club] prod is still polymorphic over sort Type/Prop ?, Matthieu Sozeau, 09/19/2016
