coq-club - Re: [Coq-Club] Ltac extend
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ltac extend
  • Date: Wed, 21 Sep 2016 19:39:11 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f180.google.com
  • Ironport-phdr: 9a23:ouaWuRZc94v+lpxZLMKfXYr/LSx+4OfEezUN459isYplN5qZpsu4bnLW6fgltlLVR4KTs6sC0LuM9fi6EjVbv97B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fn8JrKJg5MmTCVYLVoLRzwox+CmNMRhN5AI702zFPmuHxTYKwCx2pzIlSchRHn/ZaY85tq8iAWsPUkoZ0TGZ7mdrg1GOQLRA8tNHo4sZXm
> In the same vein, I would be glad if a tactic such as ‘is_var' would not be a tactic but a function returning a boolean.
Ltac is_var_bool x := tryif is_var x then constr:(true) else constr:(false).
Does that work?  Otherwise:
Class is_var_bool {T} (x : T) := decide_is_var : bool.
Hint Extern 0 (is_var_bool ?x) => first [ is_var x; exact true | exact false ] : typeclass_instances.
Ltac is_var_bool x := constr:(_ : is_var_bool x).
On Wed, Sep 21, 2016, 5:01 AM Frédéric Besson <frederic.besson AT inria.fr> wrote:
> On 20 Sep 2016, at 16:41, Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr> wrote:
> On 20/09/2016 12:09, Frédéric Besson wrote:
>> I know that you can extend Ltac with a ml tactic. I am wondering
>> whether someone knows how to extend the *functional *language of Ltac
>> with a ml function. For instance, the ml function would perform some
>> computation over an argument Coq term and return another Coq term.
> It's not possible currently, because of the limitations of Ltac
> semantics (namely, the TacML node is evaluated by-value). I think we
> could hack around that by defining a generic argument whose
> interpretation function would precisely be the ML function you want to
> use, but this is reaaaaaally ugly. If you've got an urgent usecase, you
> can probably tell it on this list so we can help you.
I do not quite get why this would be that ugly.
Isn’t it something very similar to TACTIC EXTEND with a different return type?
My understanding of Ltac internals is probably still naive...
For my current usage, returning a constr would be sufficient — there might be other relevant cases.
For the urgency. On various occasions, I  have wished this feature.
I tend to write as much as possible functional Ltac code.
Yet, when Ltac  hits its limits, I would be glad to port the relevant pieces into OCaml.
So, yes, if you can guide me through the relevant part of the code, I would like to give it a try.
BTW, if successful, would such an experiment have any chance of being eventually integrated ?
Anyway, your help would be greatly appreciated.
After a quite grep of the source tree, it seems that:
* tacexpr: there should be a new constructor e.g TacMLFUN
* tacinterp and tacintern seem to be responsible for the evaluation
  (I have no idea what kinds of terms are manipulated there.)
* Something should also happen in the parser? I have no idea where it is done...
Thanks in advance,
Frédéric
