coq-club - Re: [Coq-Club] Why does omega try to instantiate evars (sometimes)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why does omega try to instantiate evars (sometimes)
  • Date: Thu, 22 Sep 2016 10:19:20 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
  • Ironport-phdr: 9a23:hWb2bBf4NH7eVOM/8FwoVMehlGMj4u6mDksu8pMizoh2WeGdxc65Zx7h7PlgxGXEQZ/co6odzbGH6ea4BSdfut6oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JXtkbjusMKIKyxzxxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCmI4HIAUmwQ2j5FAhbI6g2yCpX2tCr5u+5w1QGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
I've had similar issues in the past with omega and ring. However, I haven't seen a case like this, where the evar is just in a local def that isn't used - in fact I was relying on such cases to not fail as I typically "factor out evars" (into local defs) before trying omega or ring.
-- Jonathan
On 09/22/2016 08:32 AM, Soegtrop, Michael wrote:
Dear Coq Users,
I have the issue that omega sometimes tries to instantiate evars and fails.
See the following example:
Require Import Omega.
Require Import ZArith.
Open Scope Z_scope.
Example Ex1 : forall x:Z, 0<x -> 0<=x.
intros x H.
evar( result : Z ).
(* works, does not use hypothesis H *)
let test := constr:( ltac:(omega) : x=x ) in idtac test.
(* fails, does use hypothesis H *)
Fail let test := constr:( ltac:(omega) : 0<=x ) in idtac test.
(* works *)
omega.
What I don't understand here is why the direct omega at the end works, but
trying to solve an identical intermediate goal fails with:
The command has indeed failed with message:
Cannot infer an existential variable of type "Z" in environment:
x : Z
Can someone shed some light on this mystery?
Does someone have a similar construct (without creating a hypothesis like
assert does) that works?
Thanks & best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
