coq-club - Re: [Coq-Club] "Official" Source for native-coq
  • From: Christoph-Simon Senjak <christoph.senjak AT ifi.lmu.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] "Official" Source for native-coq
  • Date: Thu, 22 Sep 2016 17:51:17 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=christoph.senjak AT ifi.lmu.de; spf=None smtp.mailfrom=christoph.senjak AT ifi.lmu.de; spf=None smtp.helo=postmaster AT acheron.ifi.lmu.de
  • Ironport-phdr: 9a23:ekt/tBRZchB1eKaPJL1SZMvDWNpsv+yvbD5Q0YIujvd0So/mwa67bByN2/xhgRfzUJnB7Loc0qyN4vqmATBLsMzJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbUekBDgCe3SbJ0NhS/6wvL5ecMho43AaYrywDVpWNIPt9XwGRubWmemRT15Y/k95558j9MvOohsdVNV6fzfIw5Q70eCDE7dWw4sp64/SLfRBeCsyNPGl4dlQBFVlDI
Hello.
On 21.09.2016 12:54, Maxime Dénès wrote:
Hello,
I'm sorry, it is indeed confusing.
The original "native-coq" repository is the one you found on github. It
contains a modified version of Coq with native code compilation and
primitive integers and arrays.
That version of Coq is loosely based on Coq 8.4, so it is indeed quite
outdated. Note that the native code compilation part has been integrated
in Coq, so native-coq is relevant only if you need primitive integers or
arrays.
Indeed, I am interested in the diffarray-implementation.
Since other users have asked for it, I'll try to port these integers and
arrays to a more recent version of Coq, and will keep you posted. It
should take a week or so.
Thank You
CSS
Maxime.
On 09/21/16 12:37, Christoph-Simon Senjak wrote:
Hello.
I found several repositories of native-coq, most of them seem to be
forks. What is the original repository of native-coq? I found [1] which
is by Maxime Dénès who is an author of the paper [2] so this is probably
a good source, but it hasn't been updated since 2015 and it appears to
be forked from some svn-branch.
Regards,
[1]:https://github.com/maximedenes/native-coq
[2]:https://coq.inria.fr/files/GTCoq2013_denes.pdf
