coq-club - [Coq-Club] A new coq-project-file feature based on PG
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] A new coq-project-file feature based on PG
  • Date: Sat, 24 Sep 2016 11:53:57 +0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lizhaohui1991 AT gmail.com; spf=Pass smtp.mailfrom=lizhaohui1991 AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f172.google.com
  • Ironport-phdr: 9a23:XChuGhSg+GPFzyDBX8dphvYgrNpsv+yvbD5Q0YIujvd0So/mwa64ZxWN2/xhgRfzUJnB7Loc0qyN4vqmAT1Lvs3JmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/mjabqqtaMOE1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF695nIbUngX2j5JS1zB7QP6V5Dxryqj57sk8CafNMzyC7szXGLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Hello everyone.
I have implemented a new coq-project-file feature based on proof-general.
The differences compared to the old _PROJECT file are that:
  1. New project-file can specify both coq version and coq arguments,
     so we can have different coq implementations with different projects.
  2. New project-file uses elisp language. Actually, it is just .el file.
     For example, in a project, my project-file is this:
       (setq coq-prog-name (expand-file-name "coqtop" (getenv "coq85bin")))
       (setq coq-prog-args `("-R" ,(file-name-directory (buffer-file-name)) "Certi"))
     This means I need coq8.5 and using the project-file directory as the root coq
     LoadPath.
  3. Don't like old _PROJECT file and emacs .dir-locals.el file, which will be loaded
     each time opening a coq file, new project-file is read only before we want run a
     coq file.
     Because in my experience, I always run coq file in a project, but need to see files
     in another project, which project-file should not be read to overwrite the running one.
I write this feature without touching proof-general's code, and the original purpose is
only for my own use:)
Is anyone think this useful?
Thanks ~
